3 members (Image, Graham, G4FUJ, Alan Patterson), 176 guests, and 57 robots.
Posts837,249
Thread Like Summary
Bunny, MOG37, planenut, Stevo666
Total Likes: 6
#811239 11/08/2024 9:38 PM
by MOG37
MOG37
Need help - I'm assuming this is a Bevel Box oil feeder tube. I believe that's what it was sold as - and I think that I have seen a photo or two of someone's installation. Can someone please confirm if that's what this is? Also, please point me towards any existing photos of it installed. I presume it attaches into the filler hole and then is fed up behind the seats / seat belts?
Liked Replies
by Chris99
Chris99
It looks like a system that was intended to be permanently fixed and increase the oil capacity of the bevel box. I'd leave it off and run with the amount of oil it was designed for.
3 members like this
by AZJowett
AZJowett
It is the remote Oil Fill from MorganCustoms. I use it and it does work well. If you need detailed instructions for this easy modification I have the instructions in PDF.
1 member likes this
by Bitsobrits
Bitsobrits
I have a similar line on my car that connects where the side breather once was. It is not to increase oil capacity, rather to eliminate the oil mist that came out of that breather. Also handy as a filler tube for the bi-annual fluid changes.
1 member likes this
by Bitsobrits
Bitsobrits
I did find a couple of photos. I forgot I plugged the original side hole and tapped a new one on top. The 'oil' cap at the end of the hose is the original one that previously mounted on the side of the bevel box. The hose goes towards the left side of the car then up.
1 member likes this
