Hi folks, merry Christmasto you all
Please could someone kindly confirm the number of splines on a three wheeler steering column?
I'm researching a quick release steering wheel setup for my 2012 Duratec Plus 4, and I'm rather taken with the one handed operation of the three wheeler cental push release version.
If I can find one, and it fits my Plus 4 column, it would be exactly what I'm after
Thanks in advance, Dave.
Is this so you can quickly whip it off whilst on the go, to check that rev counter Dave? 🫨😬
That's it Doug, I figured if I'm fast it should be just fine
But seriously, I was out in Monty yesterday and it started to rain, so sin of sins I had to put the roof up
It was then that I realised despite going from a 14" wheel down to 13", because my new wheel (which I love BTW
) is dished rather than flat like the original, it's actually more difficult to get in and out of the car.
This is purely a hood up thing so not a big issue as I typically drive Monty roof down, but it is a second negative along with the previously discussed obscured rev counter issue, BTW I'll likely solve that one simply by rotating the dial AKA C-Type Jaguar and the like
I've also spoken with Darren at Berry brook Morgan about the offset idea, apparently he and his team are not fans off the offset Motor Lita wheel so tge suggestion is the MorganaPark offset ring will prove annoying for a spirited driver such as myself, much as you quite rightly originally suggested.
Anyway, it's currently dry out, so I'm off to take Monty to 7,000rpm
Dave.
