8 members (RubyMog95, MartinB60, Ian Wegg, MJF, Grumpy2, Deejay, John V6, cerealsurfer), 290 guests, and 39 robots.
+8Rich 94
Posts837,268
Thread Like Summary
planenut
Total Likes: 1
#819005 03/09/2025 7:17 PM
by rcmatt
rcmatt
Y'all might recall this last fall my M3W started burning 1 quart f oil about every 200 miles (actually it had started long before that). I checked the compression and it was 80 lbs on both cylinders which everyone agreed is normal. Anyway, I was working out of state and then when I got back it was too darned cold to god work on the M3W
Today I did a leak down test. On the port side I get 100 in and about 92 on the cylinder... I thnk I am hearing air escape through the intake. On the starboard side I get 100 and 94 and the hiss appears to be on the exhaust side. So I am thinking this may be a trip to Morgan of New England for some engine work.
While I have things open.... how do I replace the cam belt"? I see three red divits on the cams but they do not seem to have any relation to anything else.
Liked Replies
#819469 Mar 13th a 09:48 PM
by Bitsobrits
Bitsobrits
The oil tank cap doesn't vent, by design. And lest you be tempted to go down the path of re-designing the breather system as some have done at great expense you should understand the factory system is fine, as long as it's working correctly.
If you haven't yet relocated the vent line from the tank to the cam case (the smaller line, RF of engine), it's worth doing as many cars have that line routed with a low dip just to the rear of the engine that can allow congealed oil foam to block that line. Frequent short drives that do not heat the oil enough to evaporate the inevitable water in the oil can create that oil/moisture foam (looks like frothed mayonnaise) and if not allowed to fully drain back into the cam case when things are hot, can lead to a blockage in the 'dip' when things cool down.
You also want to ensure the short hose from the top of the cam case to the inlet manifold is not blocked, and that the small orifice piece is in place. Also, there is a thin stainless reed valve in the cam case that needs to be functioning, and though rare, I have read of a couple of breakages.
But have you removed the air cleaner assembly to inspect the intake tracts yet? That will tell you if the engine is ingesting oil there. If not, then it's coming in through the guides or past the rings.
1 member likes this
