13 members (Chris Cosher, John V6, Gonze, Alan Patterson, Ian Wegg, DickJ, RedThree, MartinB60, sprinty, GrumpyPa, bmgermany, AndyGoff, Morganmike), 258 guests, and 100 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Thread Like Summary
xc68anc
Total Likes: 2
by riri
riri
Hallo, kannst du mir zeigen wie am meinem auto der kraftstofffiler und die benzinpumpe aussieht? Wo liegen diese teile?
danke.
Liked Replies
by +8Rich
Riri, if you PM me I will reply to you on your email with mine - you send the pictures to me and I will post them for you if you like.
1 member likes this
by CLPlusFour
CLPlusFour
Here is the answer from ChatGPT
In older vehicles, a carbon filter (also known as an activated carbon filter) is mainly used in the tank ventilation system. Its task is to trap gasoline vapors that form in the fuel tank, especially when there is heat or movement.
Purpose and function:
Prevention of emissions: The carbon filter prevents volatile hydrocarbons (gasoline vapors) from escaping directly into the atmosphere. These vapors are harmful to the environment and contribute to the formation of ground-level ozone.
Intermediate storage of the vapors: The activated carbon in the filter binds the petrol vapors.
Recirculation into the engine: When the engine is running, the stored vapors are fed back into the intake tract via a valve (purge valve), where they are also combusted.
Even in older vehicles without modern OBD systems, this filter was part of the exhaust gas aftertreatment (in particular to reduce evaporative emissions), often as early as the 1980s.
In principle, the activated carbon filter is maintenance-free and designed for a long service life - often the entire life of the car.
Hier die Antwort von ChatGPT
Bei älteren Fahrzeugen wird ein Carbonfilter (auch Aktivkohlefilter genannt) hauptsächlich im Tankentlüftungssystem verwendet. Seine Aufgabe ist es, Benzindämpfe aufzufangen, die sich im Kraftstofftank bilden, besonders bei Wärme oder Bewegung.
Zweck und Funktion:
Vermeidung von Emissionen: Der Carbonfilter verhindert, dass die flüchtigen Kohlenwasserstoffe (Benzindämpfe) direkt in die Atmosphäre entweichen. Diese Dämpfe sind umweltschädlich und tragen zur Bildung von bodennahem Ozon bei.
Zwischenspeicherung der Dämpfe: Die Aktivkohle im Filter bindet die Benzindämpfe.
Rückführung in den Motor: Beim Betrieb des Motors werden die gespeicherten Dämpfe über ein Ventil (Purge Valve) wieder in den Ansaugtrakt geleitet und dort mitverbrannt.
Auch bei älteren Fahrzeugen ohne moderne OBD-Systeme war dieser Filter Teil der Abgasnachbehandlung (insbesondere zur Reduktion der Verdunstungsemissionen), oft bereits ab den 1980er Jahren.
Grundsätzlich ist der Aktivkohlefilter wartungsfrei und auf eine lange Lebensdauer ausgelegt – oft das ganze Autoleben lang.
1 member likes this
