0 members (), 70 guests, and 61 robots.
+8Rich 70
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,885
Posts837,856
Thread Like Summary
Themorganeer
Total Likes: 1
#825653 06/19/2025 5:00 PM
by RichardV6
Mine came a little loose last night after much gear selection in London traffic. I've heard mention of grub screws but cannot see any. The lift to select reverse detent remains in correct place but the knob itself previously locked, just turns without any sign of it screwing onto threaded gear stick of the remote select MT82 gearbox.
Liked Replies
#825715 Jun 20th a 05:34 PM
by RichardV6
Result happy3 After conferring with John V6 today it seems only later 3.7 Roadsters had the gear knob style shown above, certainly from the introduction of five link rear models and likely earlier.
On a suggestion I used some curved blunt nose pliers to grip inner sleeve holding grub screws, and held arms gently in a soft jawed vice, enough to maintain a firm pressure. I was then able to unscrew outer with both hands and only modest effort after a little help from releasing fluid.
I was concerned I might damage the plastic inner further but it's just some soft rubber tubing that the grub screws bite through directly onto gearstick threads. Note MMC hacksaw butchery though which I've now squared up with careful filing.
After cleaning up components I screwed inner down and nipped up all three grub screws gently before screwing outer knob fully back on. Just one more attempt had the replaced knob with correct gearshift pattern orientation, when I nipped up grub screws with a little more enthusiasm. Actual outer knob although tightish is loose enough to allow easy removal if further adjustment is needed.
1 member likes this
