2 members (Ritchie B, Graham, G4FUJ), 204 guests, and 42 robots.
Posts837,246
Thread Like Summary
Bunny, PaulV, RichardV6, Stevo666
Total Likes: 6
#826304 06/29/2025 2:15 PM
by TrickieDickie
TrickieDickie
Hi some advice please, about 10 minutes into the drive home yesterday, there was a sudden cough a backfire and the total loss of all electrical power. If I turn the ignition key I can still deactivate the immobiliser however, there is no other sign of ‘electrical life’ coming from the car with the exception of the bottom front right relay (as you look at it) which is working over time! I have checked all the fuses which are all good, it a new (6 months ago) battery and the Regulator Rectifier has been upgraded by M3S services about 5 weeks ago.
Not a massive fan of the dark art of car electrics, can I ask has anyone experienced the same or something similar and is the solution as simple as changing the relay?
Liked Replies
#826365 Jun 30th a 06:52 PM
by Rog G
Rog G
That sounds like a dead battery, as Chris said there have been numerous Exide battery failures.
2 members like this
#826404 Jul 1st a 01:22 PM
by Chris99
Chris99
The car is negative earth so you should be getting 12 and a bit volts.
Pretty definitely a dead battery and likely partially short circuited internally so even jump leads might not help.
I'd recommend you go to Halfords and get a Yuasa U1R which fits straight in and works fine - it's what I use.
https://www.halfords.com/motoring/motorcycling/motorcycle-batteries/yuasa-u1r-garden-battery-105605.html?_gl=1*wrbkc5*_up*MQ..*_ga*MTQ5NzQ0MDgzLjE3NTEzNzU5MDY.*_ga_VK44BRER97*czE3NTEzNzU5MDUkbzEkZzAkdDE3NTEzNzYwMzUkajYwJGwwJGgw
2 members like this
#826433 Jul 2nd a 07:23 AM
by planenut
planenut
Originally Posted by Chris99
Which make of battery did you fit? There have been problems with the Exide battery in the Alternative parts list failing soon after installation.
I removed the Exide AGM 12-31 battery from the Alternative Parts List several years ago after many failures were reported. The last entry in the list of suitable batteries actually states not to use the Exide battery.
The Yuasa U1R does seem to work well and at a reasonable cost, a good buy.
1 member likes this
#826536 Jul 3rd a 02:50 PM
by TrickieDickie
TrickieDickie
Afternoon all, as advised, a trip to Halfords for a U1R battery has resolved the problem thanks again for the help
1 member likes this
