5 members (tezzer, linklaw, Plus Four Guy, BLUE+4, IcePack), 208 guests, and 41 robots.
+8Rich 70
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,883
Posts837,822
Gyp
Thread Like Summary
Hamwich
Total Likes: 1
by Iveseenitall
Iveseenitall
Hello,
I have a 2009 Plus 4 that has a fuel gauge problem that means I can't ever be sure how much is in the tank unless I drive using the trip. I know the gauges on Morgans are vague but the fuel gauge inaccuracy is something I have to address. The gauge doesn't flicker it just moves randomly by a quarter of a tank at will! I cannot fill the tank up for it to read full and I'm not brave enough to drain it. A few questions:
1. Any thoughts as to whether this is a defective gauge or is it the sender?
2. Is there a sequence, tester or process to go through to identify the exact component that's failed?
3. It's a black faced Smiths gauge with three functions - oil pressure, water temperature and fuel. If the gauge is the problem can I replace the fuel gauge part only?
4. Does the gauge come out without removing the dashboard?
5. If it's the sender I assume that I'll have to replace the full fuel pump and sender assembly? Is this relatively straightforward?
Thank you for any help.
Tony
Liked Replies
by RichardV6
Surely just filling tank to fuel hose cutoff tells you it's full [Linked Image]
1 member likes this
