10 members (Luddite, Stevo666, Plus Four Guy, Image, sewin, Happy super 3, Richardllll, John Winn, DaveW, cerealsurfer),
211
71
Topics49,883
Posts837,821
Posts: 5 |
Hello,
I have a 2009 Plus 4 that has a fuel gauge problem that means I can't ever be sure how much is in the tank unless I drive using the trip. I know the gauges on Morgans are vague but the fuel gauge inaccuracy is something I have to address. The gauge doesn't flicker it just moves randomly by a quarter of a tank at will! I cannot fill the tank up for it to read full and I'm not brave enough to drain it. A few questions:
1. Any thoughts as to whether this is a defective gauge or is it the sender? 2. Is there a sequence, tester or process to go through to identify the exact component that's failed? 3. It's a black faced Smiths gauge with three functions - oil pressure, water temperature and fuel. If the gauge is the problem can I replace the fuel gauge part only? 4. Does the gauge come out without removing the dashboard? 5. If it's the sender I assume that I'll have to replace the full fuel pump and sender assembly? Is this relatively straightforward?
Thank you for any help.
Tony
Posts: 3,826 Likes: 69
Posts: 3,826 Likes: 69 |
They all do that Sir. Seriously.
Posts: 27,825 Likes: 753
Posts: 27,825 Likes: 753 |
Use the trip. None of my cars had working guages
Posts: 8,685 Likes: 414
Posts: 8,685 Likes: 414 |
Sounds like a sender issue. The sender is integrated with fuel pump as you suspect. There is a large threaded flange at top of tank that allows unit to be unscrewed and removed. If you are willing to fault find the sender is a simple float operating on a potentiometer with slate/green and green/black wires carrying the signal to fuel gauge.
Posts: 12,263 Likes: 321
Posts: 12,263 Likes: 321 |
I agree with Richard, I'd be looking at the sender first. I replaced the sender in my 4/4 last year and was a bit surprised just how crude it was, just some windings around a piece of board with a wiper attached to a float arm. It was obvious how it had failed, the wiper arm seemed to have worn through the windings and it finally broke, leaving a rat's nest of fine wire. ![[Linked Image]](https://tm-img.com/images/2025/07/01/IMG_1609.md.jpeg) Mind you, even after making sure the new sender was set up and calibrated correctly, I still much prefer to use the trip, refuelling every 250 miles. One thing the repaired fuel gauge has done though is to reassure me that I've still got a decent range above 250 miles should I need it.
Posts: 5 |
Thank you. One concern I had when the problem occurred was establishing if the tank was full! From here you could be confident in the range via the trip. I've also been in Europe, I did 1600 miles and so wanted the largest range possible before refuelling. I worked on around 250 miles but as the tank hold 55 litres (350+ miles?) I couldn't help but think I was stopping more often than I ought to.
Surely just filling tank to fuel hose cutoff tells you it's full ![[Linked Image]](https://series2club.co.uk/2023_new_forum/Smileys/wittsends/nixweiss.gif)
1 member likes this:
Hamwich |
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
My plus 4 is similar; it generally shows just over 3/4 with a full tank. An alternative is to let it run to showing virtually empty…locally; ( carry a spare can if you’re worried about getting stranded), then go to a filling station and fill the tank until the pump cuts off. Under those circumstances on my Plus4, I can only get about 37 litres or so in, so with a 55 litre tank, I have confidence that I can get at least 100 miles before getting concerned, even allowing for some that may not be pumpable in the bottom of the tank.
I couldn't help but think I was stopping more often than I ought to. Not an issue for me, my bladder range is much less than that!
Posts: 28,908 Likes: 354
Posts: 28,908 Likes: 354 |
I couldn't help but think I was stopping more often than I ought to. Not an issue for me, my bladder range is much less than that! I know the feeling!
