9 members (Soleng, B3MOG, TBM, Bitsobrits, KLASG, ch44, Morganmike, TalkMorgan, gaston), 272 guests, and 57 robots.
+8Rich 95
Posts837,265
Thread Like Summary
Jon G4LJW, xc68anc
Total Likes: 4
by Adam12
Adam12
Where I live there isn't convenient access to any Morgan specialists or anything like that so I will be having annual service performed on my 2019 +4 by a local garage that has at least some experience with "exotic" cars. My question, if I may impose on the wisdom of the citizens of TM, is what should actually be done on an annual basis?
I assume annual oil and filter change of course, and I can look up other requirements for the Ford 2.0 l engine and the Mazda gearbox. But are there Morgan-specific periodic service items/checks that I should ask the mechanic to perform? (Note: I have learned how to grease the kingpins and already take care of that myself, but I am not at all a mechanical person so will be hiving off the service to someone who at least somewhat knows what they're doing smile ).
Any guidance gratefully received!
Adam.
Liked Replies
by Deejay
Deejay
From my experience, in particular:
1. Spark plug bodies are notorious for corroding due to moisture getting into the plug wells, so unscrew, clean and re-insert every year. A stuck plug in an alloy head is no fun.
2. Remove rear brake drums annually and check brake cylinders have not seized;, apply ceretec grease or similar under dust boots.
3. Lubricate rear spring leaves with motor cycle chain oil (one that is suitable for o-ring chains)
4. Spanner check every nut and screw, as screws in particular come loose
5. Check diagonal tie-rods from top of cross frame to chassis rail; I have had two break over the years and it doesnโ€™t look obvious unless you give them a shake. (Do this every time you grease the king pins.)
6. Lubricate the pedal box and clevis pins annually
2 members like this
by Adam12
Adam12
Thanks Jon that's really useful -- a bit embarrassed I didn't think of that myself! (Love the way ChatGTP so sycophantically states what a fantastically great question it was tipshat )
1 member likes this
by Image
Adam ... never trust a robot! ... once they get their feet under the table they'll be as rude as we are!!! ๐Ÿ˜†
Decent list though! ๐Ÿ™‚
1 member likes this
