5 members (High Hamster, jbk, Image, Hamwich, Farmershands), 203 guests, and 69 robots.
Posts837,248
Thread Like Summary
Bunny
Total Likes: 5
#830640 09/15/2025 8:30 PM
by RedThree
RedThree
Having had the wheel speed sensor pack up, bodging it to get it working again and realising that I needed a new one, I got one of Andrew's (Bunny on here) long lead sensors which arrived today. This evening I steeled myself to fit the new sensor which was obviously a classic ten minute job and ten minutes after starting it was all fitted, cables neatly routed and secured and working as it should. I don't think this has ever happened before. No random rivnuts spontaneously started spinning, no other bits fell off, nothing broke and it all just worked. Very strange.
Thanks to Andrew for a good, sensible kit of bits to do the job.
The ten minutes does not include the hours poring over the loom diagrams and rummaging behind the dash trying to find the wire that I had obviously disturbed while fixing the indicator stalk button wiring that had come apart. The speedometer had packed up as soon as I had got the button working again so it took a while before I thought to test the hall effect sensor which had decided all on its own to fail as soon as I had fixed the other electrical gremlin, presumably out of spite.
Liked Replies
#830663 Sep 16th a 09:30 AM
by JMD
JMD
Very happy with the kit - fitted easily and gets the connector neatly out of the weather ... done as preventiv emeasure rather than because of failure ... and the old one is in the spares box...."just in case"
1 member likes this
#830645 Sep 15th a 09:14 PM
by RichardV6
Sod's law dictates this is an unusual scenario but what euphoria when a well researched job provides the expected outcome and happens in a timely manner without rushing thumbs
1 member likes this
#830952 Sep 22nd a 08:41 AM
by planenut
planenut
If replacing the TSM doesn't fix the problem with erratic tacho indications and engine cutting out, it may do as it does a lot of strange things, I would have a look at the Crank Position Sensor as that feeds an engine speed and position signal into the ECU for ignition and tacho indication. Bunny also does a replacement one of those at a very reasonable price 😊.
1 member likes this
#830968 Sep 22nd a 03:37 PM
by Chris99
Chris99
Originally Posted by Piloto
Andy: Thank you very much for the information. My apologies for confusing the source for my updated turn signal module. What I have is a more robust turn signal module that was supplied by Alister Watt, to whom you were kind enough to refer me.
I was a bit dismayed by the recent failure of my Morgan-supplied Turn Signal Module, and I suppose I have to resign myself to whatever quality- control (or lack thereof) is being implemented by the factory.
I will be installing the Watt TSM, and hoping for a better result.
Best regards,
Tom
Hi Tom, the Alister Watts TSM came via me. He has a minimum economic batch size for production so I have been ordering batches and passing these on at cost.
The MMC module has a fundamental weakness to over or reverse voltage whereas Alister's has robust built in protection for these. It also has additional functionality in allowing user selection of the time before automatic cancelling (nominally 7 seconds, 14 seconds or off) and also functions as a peak battery voltage recorder which can help check the health of your battery.
1 member likes this
