0 members (), 318 guests, and 40 robots.
+8Rich 94
Posts837,276
Thread Like Summary
Total Likes: 3
#832685 10/23/2025 11:24 AM
by Peter G3VNH
Peter G3VNH
Morgan 4/4 starting problem.
I am having problems starting my 1994 4/4 Zetec 1800 Silver top engine. The battery is in good condition and holds its charge.
When attempting to start the engine it just goes ‘whrrr as if a flat battery’ and the battery indication on the dashboard drops to around 5 Volts. When the ignition is turned off the battery indicates normal level.
My measurements with the ignition OFF is 13.4V, with ignition ON is 12.5V and the measurement at the input to the starter motor is 12.4V. This indicates a voltage drop of 0.1V down the length of the cable from the rear to the front. Is this voltage drop acceptable? When turning the engine over the voltage at the starter motor input drops to 6V.
The vehicle can be started by directly putting 12V onto the starter motor input. The engine then fires up first time.
I hope it is not the voltage drop/resistance along the cable causing this as it does not look an easy job to replace.
Has any member any ideas on this problem. Thanks in anticipation.
Peter Hardy
Liked Replies
#832693 Oct 23rd a 12:21 PM
by John V6
If it is agell battery they can sow as fine but under load fail. I had the same on my CX.
How did you put 12v directly onto the starter? Whas it the same battery?
It could be also a poor earth. They may look good but disconnect & clean them.
1 member likes this
#832702 Oct 23rd a 01:50 PM
by Image
You could check the voltage at the battery terminal when cranking the starter ... if it drops to 6v like the starter input then it's the battery but if it stays up around 12v it's likely a bad connection issue in one of the heavy cables to the starter
1 member likes this
#832829 Oct 25th a 05:02 PM
by Peter G3VNH
Peter G3VNH
I have just spent the afternoon cleaning all the earthing points. The car starts now and the only connection which really showed dirt/contamination was the engine block to chassis. No doubt it will be even better with a new battery and give me confidence that it will start. Thank you all for your 'remote' assistance.
Regards and safe motoring.
1 member likes this
