8 members (DPEvans, Rovert, MartO, Ritchie B, +4competion, +8Rich, JohnHarris, Alan Patterson), 243 guests, and 48 robots.
+8Rich 99
Posts837,259
Thread Like Summary
Bunny, Pyewacket
Total Likes: 4
#834158 11/22/2025 2:43 PM
by Pyewacket
Pyewacket
Has anyone fitted a “dry break” connector to the rear brake?.
Liked Replies
#834162 Nov 22nd a 03:55 PM
by SCX358G
SCX358G
or maybe these:
https://www.demon-tweeks.com/uk/wil...-disconnect-brake-line-fittings-7000847/
(i have no personal experience of using anything like this.... just was curious to see what a 'dry break' was)
1 member likes this
#834159 Nov 22nd a 03:26 PM
by Herrie
Herrie
when you mean something like
https://www.stahlbus.com/products/en/bleeding-system/index.php
In that case I can certainly recommend it
1 member likes this
#834165 Nov 22nd a 05:33 PM
by RedThree
RedThree
Yes! I have.
Ideally you would want to shorten the brake line and fit a short flexible line from the brake so that the connection is somewhere along the swing arm to give the flexibility to do the half twist to make and break the connection. I just have a 90 degree swivel elbow on a nipple into the slave cylinder then the dry break and a small bracket to support it.
I would describe it as almost essential but it definitely isn't quite there. When breaking the connection, I always have a small screwdriver in my hand as the self sealing valve on the master cylinder side often sticks open and needs lightly prodded with the screwdriver to get it to seal properly. I don't think it seals all air bubbles out quite as well as you would hope but, I very much do not need to bleed the brake every time I disconnect it and I was never happy leaving the line connected when taking the wheel out so I had needed to bleed it very often before I fitted it.
1 member likes this
#834210 Nov 23rd a 06:43 PM
by Rog G
Rog G
https://auto.helperformance.com/hose-and-fittings/quick-release-dry-break-couplings
This where I bought mine from, I also bought new brake lines from them, caliper to quick release and quick release to bulkhead fitting under the oil tank.
1 member likes this
