3 members (John Winn, TBM, piquet), 231 guests, and 54 robots.
Posts837,251
Thread Like Summary
Luddite, Martin W
Total Likes: 2
#838562 02/15/2026 12:38 PM
by Herrie
Herrie
A simple chain-oiler
I found on TM a question about chain-oilers https://www.talkmorgan.com/ubbthrea...-three-chain-drive-conversion#Post837992 and thought to write about my experiments with it.
When having a chain conversion kit, as for instance sold by Phill Bleazey, a chain oiler is essential.
Besides good alignment of the Bevel-box with the rear-wheel - another article to be coming - a not good oiled chain is the main cause of noise with a chain.
When you do not oil the chain regularly, the rollers in the chain will wear out which gives metal to metal noise.
The most simple method is buying a brush on the internet and put some oil on it and brush the chain with oil.
On amazon : Bike Chain Cleaning Brush € 7 for 2 or 4.
Advised is to use around 80-SAE but I like to use 250 severe gear oil because I have it on board for my Bevel-Box lubrication and it works perfect too.
Every time after topping up the fuel tank you lift the car so your rear wheel can freely turn and use the special brush to lubricate the chain. Not more than 15 minutes work.
Actually in normal conditions – no snow, no rain, no mud – this is enough for 600km.
You will get some splashed oil on your rear-wheel mud-protector but when you have to work on the rear wheel you can clean this at that moment.
But when you do not want to jack up the car or are very often - like us - on the road for longer trips a chain-oiler is an easier solution.
I tried several of them and was sometimes partly pleased especially with the most cheapest one I could find.
You can spend a lot of money on automatic and GPS regulated oil-sequences, but you spend a lot of money which is not necessary.
For me a hand pressure system works fine.
Every time I am at a fuel station I open the trunk, turn ½ a turn or more on my pressure tank/ cup and a ¼ back. That’s enough.
Remember that every extra system will create also extra failures and will need extra care and maintenance.
So keep it simple, but not stupid.
When I have some time I look under the ‘car’ - I like ‘Trike’ for a M3W as a better word - to check the lubrication of the chain.
And when I do maintenance – and for me this is the main reason for having a M3W - I put a carton under the rear-wheel and use some air pressure to clean the tube and the chain oiler from mud.
I experimented for a while with the nice Loobman system - https://www.loobman.co.uk/ for € 36 - but after a while I did not like his oil pressure system by a button, because it did not work well.
It needed actually to be open for quite a while, so I used a plastic ribbon to keep the button down which gave then too much oil.
Too much oil is not a problem for the chain but it is for the environment.
But my main concern was that when you contact Denis Loobman for spare parts he never answers. So very bad after-sales services.
The idea of just a simple tank and oil pressure button of the Loobman inspired me to have a look at the so called ‘NEMO’ system.
There are a lot of complains about it.
It keeps leaking is the main complaint, but in most cases that is due to not understanding the system.
When the little tank is filled you have to turn it 2 rounds down and then ½ a turn back to create under-pressure.
The under-pressure you create in that case in the top of the tank will stop the oil for running further. Like a bird watering system in your garden.
It is also important to have the whole system well air-tight installed so no extra air bubble can go up.
To get the tube good air tight I uses Tefgel and Teflon-tape in the fittings ⅛ “ BSP and used a reinforced mantle AN-3 break-line hose.
Thick oil will help also with this, which is another reason I use again the 250 grade severe gear.
Using it and simply fill this little tank I had to install the tank under the ‘boot-lid’ attached on the ‘Boot inner tray’ so I could use it easily when opening the ‘boot-lid’.
But with this solution you have a problem.
When you have to take out the ‘Boot inner tray’ – which is for me quite often - you have to disconnect the tube.
I used an ‘AN3 Quick Release Motorcycle Dry Break’ to easily disconnect the hose.
In case of a longer stay in the garage, I installed a small ⅛ BSP ball-valve behind the little cup/ tank so I can close it.
When checking or filling the cup I use the ball valve too.
And in case I should have a leaking device like others are complaining about, this ball-valve will help me.
There are several solutions to get the oil at the chain.
Most common is a small tube directed to one side of the chain near the rear-wheel sprocket.
I tried it but was not convinced.
I opted for the Loobman because of the little gaff/nozzle he uses which forks at both sides of the rear-wheel sprocket.
Cleverly using a tiny tie-rib to direct the oil aside.
But after losing one of these gaffs which is normal with the rubbish on the roads I could not get a spare new one.
I found a gaff/nozzle at ‘Pro-oiler’.
This one works different and just drips the oil slowly at both sides of the sprocket.
Centrifugal force will direct the oil around and in the chain. Which is helped by the reason that behind the sprocket teeth the sprocket is thinner so at first the oil stays at that ridge.
The gaff/nozzle is delivered with a sturdy but flexible rubber hose with ID 4mm which fits nicely on a barb fitting.
To get the rubber more fixed I used a small piece of standard copper pipe to cover it, but it still can move enough for installing it around the sprocket teeth.
I made myself a support for the gaff-connection on the swing arm with piece of 2mm aluminum plate.
I bended an outer part of this 2 mm aluminum plate to make a hole and fitting for that barb fitting male at one side and a female ¼ BSP at the other side of the aluminum.
One of the barbs is connected with the hose the other with the rubber of the gaff/nozzle.
To get more grip on the aluminum plate I used here the ¼ BSP instead of a ⅛ BSP.
The aluminum plate is fixed with two M5 Alan-bolts in the existing holes for the Mud guard.
My swing arm has 2 rivet-nuts at each side so also two holes in the mud-guard bracket to attach the mud-guard. I drilled the front mud-guard hole of 5mm to the size of the Alan head.
I first install the chain-oiler plate on the swing arm and then the Mud-guard so the front hole can slide over the Alan-bolt head.
I fix the aft Alan-bolt of the Mud-guard bracket and when I want – but never do – I can use a little extra washer to fix the front again.
Actually you need only one bolt to fix the mud-guard bracket to the swing arm as shown in the ‘M3W-Parts-Book-V5.2’.
Estimated costs
‘AN3 Quick Release Motorcycle Dry Break’ on Amazon € 22
5 feet ‘AN3 PTFE Hose with Stainless Steel Braiding’ on Amazon € 26
AN3 to ⅛” NPT connector to the dry-break € 11
⅛" BSP Hex Nipple; ⅛" BSP Hex Coupling, ⅛" Female & Male BSP 90 Degree Elbow 4mm x ⅛” BSP Male Barb Connector € 7
⅛" Mini Brass Ball Valve ⅛" BSP Male to Female € 11
I found a copy of the Nemo tank on Ali-Express for € 12
I bought some extra barb fittings ¼ BSP for a connection to a gaff which is actually the oiler on both sprocket sides.
For the gaff system I bought the small gaff from Pro-oiler. The mini-nozzle for € 18
The great thing of Pro-oiler is that you can buy spare parts like the nozzle separately
Total € 107
Worktime : a couple of hours.
Some extra chain information
Working on our Bevel-box-project, after more than 12000 km usage I dissembled the whole chain-drive conversion .
Gave it a serious check on chain and sprockets but could not find any reason why to renew it so installed the old stuff again.
Tsubaki
Advises to change the chain with an 1,5% elongation
Measured over 6 rollers
L1 Inside 6 rollers
L2 Outside 6 rollers
L = ( L1 + L:2 ) /2 = 95,25 mm
1,5% elongation = 96,68 mm
Tsubaki
“When the chain speed is fast and the load varies Roller chain may vibrate if the natural vibration frequency of the chain, shock frequency of the driven machine, or chordal action of the chain (vertical pulsation of the chain due to the polygon effect) synchronize. In this event, use a guide shoe (made of NBR or ultra-high polymer polyethylene) or other device to stop the vibration.
You can take a gap of 2 to 4 mm between chain and contact surface.”
--> This is a noise related issue, and because I am not disturbed by chain noise much it has not a big priority for me.
Because of the fun, I will experiment with some simple and easily to be installed solutions.
Tsubaki
“Drip lubrication
Using a simple case, this method drips oil supplied from an oil cup
For one strand of chain, drip about 5 to 20 drops of oil each minute. Drip more oil on higher speed chains.”
--> In my experience I think this is a little too much.
Tsubaki
When controlling a well lubricated chain
When the chain is stationary, the chain surface will generally appear dirty from wear dust if lubrication is unsatisfactory. This is especially the case between the link plates.
Which means that a chain should be reasonable clean. A Good oiler system cleans the chain too.
Liked Replies
#838576 Feb 15th a 06:16 PM
by RichardV6
"O" or better "X" link chains are another consideration. They refer to the shape of grease seals fitting inside the chain plates and rollers front and back in order to retain grease. There still needs to be lubrication between rollers and sprockets of course. Also of importance is regular cleaning of excess lubrication from chain which otherwise amalgamates with road dirt then acting like a grinding paste.
1 member likes this
