2 members (Image, Graham, G4FUJ), 154 guests, and 51 robots.
Posts837,249
Thread Like Summary
MartO
Total Likes: 1
#845163 06/18/2026 7:51 AM
by MartO
MartO
2025 Plus Six. I have a clunking sound over bumps when the suspension has to work hard. It sounds like it is from the rear. It's a bit like a sound I had on my previous TR3A, which was due to the rear body to chassis mounts needing attention. Muted, not violent sound, but like something quite weighty is loose. A sound a bit like something heavy and unsecured knocking about in the boot.
Done so far:
- I have checked all underside bolts and under the circular vented rear cover (no spare wheel). Actually, several were not that tight and took half a turn. But it hasn't solved it.
- Wheels off and no noticeable play.
- My dealer test drove it, when I had it serviced. They told me it is fine, a normal Morgan noise over bumps.
Is that the case? If so, I can live with it. It drives fine and over 50mph is actually quite a compliant ride! But, it is niggling in the back of my mind that I should double check. Would welcome views from those with more Morgan (+6?) experience.
Liked Replies
#845167 Jun 18th a 09:24 AM
by Davetherave
Davetherave
We have a 2020 Plus Six, I have been looking for a low level clonk from the rear when driving over potholes at low speed for the last 4 years. Each year I check everything in sight, from the suspension to exhaust.. We replaced the standard shock absorbers with the SSL touring option several years ago, this reduced about 50% of the noise but once your brain is adjusted to the noise you seem to notice it. I have found that after the yearly underseal spray with lanoguard the noise vastly reduces for roughly 50 miles, so I think its more likely a coilover spring compression noise as the spring works under a heavier load. The upper mounting bolt of the rear coilover unit connects to the body fairly close to the drivers side and there is not a lot of sound deadening in that area, so any mechanical noise is easily heard.
There are a couple of things to check though, make sure the hand brake cable is secured and not rubbing on the rear suspension wishbone when its under compression, also check that the rear inner plastic wing is fully secured, two of the studs that hold this in place are bonded/glued to the alloy, they can come loose and need rebonding. On the 2020/21 MY they are located at the lower front of the wing liner and on the outer rear of the wing, you will see they look like a stud rather than bolts that are used in the other locations ( this may still be the same on a 2025 MY). Lastly check the rear exhaust rubber hangers, we had one that had moved and rubbed against the main alloy bodywork.
1 member likes this
