7 members (Robbie, Clipper, cerealsurfer, DJC, MJF, verysideways, TalkMorgan), 241 guests, and 43 robots.
Posts837,252
Thread Like Summary
MogPat
Total Likes: 2
by MogPat
MogPat
Car: 1990 Morgan Plus 4, Rover M16i engine, 1994cc, DOHC 16V, indirect injection, Lucas 14 CU electronics.
Situation 1 – Cold start, then driving outside: the engine runs smoothly and stable.
Situation 2 – Cold start, drive outside briefly, switch off the ignition, close my garage door (only a minute or two), then restart the engine (still essentially cold). At this point the idle speed rises to around 1700 rpm, then drops to around 1000 rpm, then back up to 1700, then down to 1000 again — repeating this cycle back and forth.
Has anyone experienced this same pattern, and if so, what turned out to be the cause?
Liked Replies
by John V6
Check al the air hoses. There is a vacuum line sizzed hose from the inlet to the ECU (at least on a T16) that easily perishes.
It could be the start of ECU failure , mine would idle fine, not at all or at 5,000 rpm.
1 member likes this
by jbk
jbk
Yes MogPat, you are of course correct, however I am reluctant to entrust my ECU to a repairer as I do not have a spare. It works ok when running so until I can find/ buy a spare to send for repair I will live with the intermittent tick over.
What I am suggesting is due to the age of the ECU buy a spare, you may have more luck than me sourcing one.
My ECU is Motorola MKC100034 E if anyone out there has one even if it needs repair.
It would appear it comes from a Rover 820 around 92/3 most of which were exported to Spain it seems.
1 member likes this
