1 members (RichardV6), 298 guests, and 31 robots.
+8Rich 92
Posts837,278
Thread Like Summary
Total Likes: 1
#848730 08/26/2026 5:31 PM
by ScottMellor
ScottMellor
Greetings to the brain trust.
I wanted to grease the front suspension on the delightful 2019 3.7 Roadster I just purchased from Morgans West. I had added about 400 miles since taking stewardship.
I purchased a Lock N Lube Pistol grip 5000, a 90 degree adaptor and Valvoline Moly Gray grease and set about it.
I did not jack the front end up this time because of space constraints due to construction at Mi Casa.
When I started pumping on the upper zirc fitting, the handle squeeze felt normal. There was a slight hissing sound. I did 6 pumps and saw nothing coming out of anywhere so I stopped and did the bottom also 6 squeezes. Still nothing expelling from any orifices. I did the other side exactly the same with the exact same result.
Is that a normal result?
Thanks!
Liked Replies
#848744 Aug 26th a 09:49 PM
by ScottMellor
ScottMellor
Hi and thanks for pointing that out. I absolutely cleared the grease gun prior to starting. It took a bit to get it working but once I got it situated I verified grease pumping smoothly all the way through the hose before I started. Also you know the smooth pressure when pumping has a different feel than when you are pumping nothing.
1 member likes this
