6 members (RichardV6, BLUE+4, mph, John V6, Sir Percival, TBM), 214 guests, and 71 robots.
+8Rich 76
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Topics49,889
Posts837,903
Morganzeal, Pablo
#454729 12/06/17 06:59 PM
WDR Offline OP
Had a short trip in my 3.0l 2004 Roadster this afternoon with no problems at all.Just tried to start it this evening to put it away and it won't start,Turning over as normal(battery is new) but nothing happening.I disconnected the battery and reconnected to clear any ECU faults ,also pressed the inertia switch down.The MIL goes off as normal so I'm a bit stumped.Any ideas?
Fuel pump relay?
Bud
4/4 "Stanley"
WDR Offline OP
Many Thanks I'll swap relays around and see what happens
WDR Offline OP
Thanks for the suggestion,but no success I'm afraid,checked all fuses and relays and yes there is fuel in the tank before anybody asks !
Silly suggestion, but is it worth trying your spare ignition key?
Bud
4/4 "Stanley"
If it's not fuel then it might be the spark? Can you easily check if the spark plugs are sparking?
+8 4.8
sid Offline
A few years ago I had a Volvo V70R, a bit of a tyre-shredder with 240 bhp going through the front wheels, but a lot of fun. However, after any relatively short journeys it was a bugger to start. A local specialist gave me this tip, which worked every time:
1. Push throttle pedal to the floor and hold it there.
2. Turn on ignition and spin starter motor for several seconds.
3. Engine will eventually cough and splutter.
4. When it's running on all cylinders, immediately lift off the throttle.
A completely different motor, I know, but possibly worth a try.
Sid
Ex 2014 3.7 Roadster in Ferrari Le Mans Blue
Ex Indigo Blue '99 +4
Ex MogMMX Innovations winner
Used to use that exact method on a bmw 2002ti many years ago.
Nick
Have had this on my plus 4 and it was the fuel pump relay ! So must be fuel not getting to engine due to ...or spark eg coils ? Check spark ! Apologies if I'm wrong but I've been there !
U
TM Photographer of 2008
U
Do you hear the fuel pump energise when you turn the ignition on? (I assume a 2004 Roadster produces similar clicking and whirring on turning on the ignition as a Plus 4)
Ken
