1 members (+8Rich),
273
92
Topics49,872
Posts837,705
Posts: 10 |
Some years ago the cylinders were replaced by the then Morgan dealer after a leak was detected during the austrian MOT. WIth the new cylinders the clutch was significantly immediately heavier. As I understand it the relative diameters of the cylinders determines the softness/hardness of the clutch. Unfortunately old cylinders were disposed of before I collected the car.
Can anyone tell me what the correct Master and slave cylinders for my car should be. Standard Kent engine and I think Escort gearbox. Are they still available and if so where? Clutch has always been a minor issue but no-one was able to diagnose without taking engine and gearbox out. Sadly clutch hac given up the ghost so I'd like to address the cylinder question whilst this work is in progress.
Thanks in advance
mfg
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
For a 1971 car there should be a mechanical linkage rather than a hydraulic cylinder.
Cylinder is from a Ford 105E but they were scarce a few years ago so I am not sure if the availability has changed since.
A few did come on the market but the machining was very poor
Arwyn
Posts: 1,149 Likes: 19
Posts: 1,149 Likes: 19 |
It is possible past parts at Bury St Edmunds would reline the cylinder and provide new seals. see here https://www.pastparts.co.uk/
Morgans 1934 MX, 1947 Series 1, 1956 +4 TR4, 2000 +4 T16 Triumph Herald 1969 13/60 Morris 1970
