Topics49,867
Posts837,629
Posts: 1,575 Likes: 55
Christmas Quiz - A or B?
Sorry to put this in here instead of the maintenance section but I couldn't find a way to put a photo in an ordinary post.
Can anyone help - A or B for the axle stands (one each side obviously)?
Posts: 347 |
I had difficulty in raising a wheel using the supplied jack so made an extension tube - see separate posting in the Morgan photo gallery.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Don't forget to carry a piece of wood to stand the jack on in an emergency..........
Posts: 12,260 Likes: 318
Posts: 12,260 Likes: 318 |
I always place the axle stands outboard of the chassis, but close to it.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Also depends how wide the bed on your trolley jack is, if you use a wide general garage jack and a large pair of axle stands you may have to put them in the outer position in order to withdraw the jack afterwards....assuming you want to work in the middle of the car or drain oil etc.
