2 members (Soleng, Plus Four Guy), 271 guests, and 42 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
#347532 14/03/16 10:48 AM
3 Images
Kent Rocker Arm components
4 Comments
I'm intrigued, Colin. How does this system work?
Obviously it does work, and has done so for donkey's years, but I would have thought that if the thread forms are mismatched, then the first time the adjuster was wound into the rocker arms then either the male thread or the female thread or both would be damaged?
Just a high resistance between the thread forms I guess, perhaps the most strange thing is even when you unscrew them to widen the valve clearance the things do not work loose. As you say Ford have built millions of units with this system and its not a fail item I have ever heard of.
BR Colin
SBM Offline
It just goes to show that sometimes, the KISS principle works best..
I have them on my pre-crossflow 1500 because the old type was not available any more when I had to completely rebuild the engine 7 years ago (a valve dropped and played havoc). I don't like them because in my case they usually get loose after approx. 2000 mls. So valve clatter is always there. I wonder if the old type would be available again.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
