Topics49,852
Posts837,446
Posts: 1,873 Likes: 174
Some pics of my new MK dash with MorganPark stalks
[url=[URL=http://s1187.photobucket.com/user/Bianchi161/media/12993512_1003641199716711_7469512184940345713_n.jpg.html]  [/url]]New MK dash[/url]
Posts: 1,873 Likes: 174 |
See also this thread!
http://www.talkmorgan.com/ubbthreads.php/topics/355166/Re:_New_Matthias_Kauffelt_dash#Post355166
I gave the Morgan a good clean after I collected her at Klaas Booij in the Netherlands. The new MK dash looks lovely, the switches feel solid and the new MorganPark steering column stalks operate, feel and look fine. It was quite a bit of work installing the refurbished stalks, very little space with also the new SS cover. But in the end: a good result!
Ruut Bianchi Morgan PlusFour 2023 Bentley Midnight Emerald Morgan 4/4 4-seater 1990 Royal Ivory
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
I do like that centre panel, that rotary light switch in particular looks very smart.
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
That is very nice indeed. It has a classy 60's Jaguar look to my eye.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Indeed, the rotary light switch is a 60's, or even earlier, one from a Jaguar. The whole set up looks really nice, well done.
This switch is MK's interpretation of the old Jaguar switch. I you use it you wonder why they ever changed such switches....!
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
Your volt meter seems to be registering about 11.5v. Is it on all the time, or is your ignition switched on?
This switch is MK's interpretation of the old Jaguar switch. I you use it you wonder why they ever changed such switches....! Cost I suppose Ruut, my Grandfather used to run a MKX Jaguar with twin fuel tanks and the changeover switch was a similar type from memory.
Your volt meter seems to be registering about 11.5v. Is it on all the time, or is your ignition switched on? John, that happened a long time ago after I had little holes drilled in the 4 central meters to prevent them from damp inside. It didn't work out well, and after that the voltmeter never returned to zero if ignition is of. But for the rest it seems to function well for many years already, so I left it that way.
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
