5 members (howard, PaulJ, davewhite, IcePack, Alan Patterson), 345 guests, and 82 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
#360732 01/05/16 01:30 PM
4 Images
Peter J Offline OP
Formerly known as Aldermog
Wind Deflector Prototype
A I discovered soon after taking delivery the Aluminium Chassis Plus 8 seems to be very good at collecting road dust inside the car and if the road is damp, picking up moisture and dumping it inside the cockpit and one the inside of the screen.
I had a Williams wind deflector on the Roadster and it seemed to help. But a Plus 8 is rather wider, collects more muck and so an alternative solution was needed.
Step 1 was to have Aero Racing fit the roll over bar they developed for Aeroman.
Step 2 was to make a prototype wind deflector and road test it.
These photos show the evolution of the screen and the finished card prototype. The fitting, using zip-ties is temporary, the final version will clip to the roll bar frame.
The hole, covered by fly screen mesh, was put there for two reasons:
1. So I could see behind
2. To see how much air comes through this space. The answer was "a lot"
The cat is removable amd simply there because he likes sitting in the sun. He is, of course, nicely colour coordinated!
A road test today shoiwed it is promising..the Co-Pilot said that the cockpit was quieter, her knees didn't get cold and she needed neither scarf nor at lower speeds, a hat.
So, the next step is to make a second prototype, check for fit and then have a final version made.
Initially I'm going to get one made in plexiglass, for three reasons..
1. It will be all but invisible..
2. It is a lot cheaper than a custome made "frame and net" one, about £120 and the maker is near Southampton.
3. I think it will work better, based on the prototype road tests.
The finished version will be in use by mid June..., I'll report further.
Oh yes, if you want a roll bar for your modern Plus 8/ Speedster it will be about £800 plus VAT from Aero Racing and they need your car to fit it.
21 Comments
Your exhaust tips are filthy wink
Mark - No Longer driving
I thought that the Cat should be fitted fitted underneath !
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
Peter J Offline OP
Come over and you can polish them....!!
Looks like an interesting project.
Martin (Deano)
This is the standard.
Hey I've just posted an image on a gallery thread without doing anything special? thinking
Drive on the Wild Side
Pussy Galore I see. innocent
Adrian
Rog Offline
Have you considered slightly tinted? I use mine a lot and it does attract the road grime so requires regular cleaning. The tinted is quite forgiving compared to my clear side screens in this regard. The tint goes some way to hiding scratches, scuffs and cleaning marks.
Roger
My next one will be light grey tint for that reason.
No, that is an illness........ laugh2
BR Colin
