0 members (),
310
42
Posts837,277
Posts: 14,748 Likes: 158
Work in progress 2
The right hand bonnet half without the scoop was finished a few days ago but the left hand half with the scoop required a little work. I saw it nearly finished today.
My mod for the heater/aircon intake was finished today. I made the blocking piece from a sheet of PVC cut and bent into shape. Where the material was bent a crack opened but it is only in the upper surface and I will use a little black silicon to fill it. If ever I replace it I will probably use a piece of aluminium instead now that I have the shape needed.
The closed cell foam is fairly light and will sit against the under surface of the bonnet insuring that only outside air, not hot engine bay air, enters through the louvres and into the heater airbox.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 1,515 Likes: 60
Posts: 1,515 Likes: 60 |
That looks a very neat job indeed.
Posts: 1,127 |
Welcome to "the club" dear Peter
It doesn´t matter how fast it becomes, but how it becomes fast.  2015 Roadster 3.7
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
That really looks great. Some excellent metal work skills on show and it now looks "all of a piece"
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
The closed cell foam is fairly light and will sit against the under surface of the bonnet insuring that only outside air, not hot engine bay air, enters through the louvres and into the heater airbox. After the sizzling heat over the past few days I am inspired by your solution to the uncomfortable heat in my 4/4 cabin. Its a mod I shall take on board as soon as I get home again. Thanks for your post here Peter.
