1 members (+8Rich), 312 guests, and 90 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
#44372 11/05/10 06:59 PM
5 Images
Andy Offline OP
3rd Brake Light
My solution to the Issue. DIN socket mounted next to the Cobra head and spliced into loom inboard of the existing connector
22 Comments
Dinodan #44501 14/05/10 04:06 PM
Green & Grown Up
Green & Grown Up
Originally Posted By Dinodan
No problem. Just drill a hole through the tyre.
Seriously though,
I did think that a smaller Din Socket ( large audio Jack Plug size) could be fitted through the underside angle of the Cobra Lens Glass (and maybe Reflector). That could have eased the wiring issues as well. idea
If Tail Lamps are mandatory in Europe then the Morgan factory could fit this (or similar socket)in the Cobra as standard and then offer a 'Grand Designs' Suitcase Tail Lamp as an extra. (Hurrrmph!)somestick
Andy Offline OP
Frank
My tyres are 195/60 R15. Looking at the handbook the roadster is listed as having 205/60R15. This would I suppose account for the lack of gap.
Andy
Andy #44510 14/05/10 08:04 PM
That would only be 3mm difference on the tyre radius...
I wonder if the rear panel on Frank's Roadster actually has a smaller diameter hole for the spare wheel mounting...
Nothing like hand made cars laugh2
Cheers,
Andy #44511 14/05/10 08:17 PM
Green & Grown Up
Green & Grown Up
Originally Posted By Andy
Frank
My tyres are 195/60 R15. Looking at the handbook the roadster is listed as having 205/60R15. This would I suppose account for the lack of gap.Andy
Hi Andy,
The tyre is the size you quote - Avons
Here is the close up used for my Avatar = Not much of a gap.
Actually there is a gap of about 1.5cm all around.
The Close Up
Frank
Hi Andy,
The Close Up
Hi Franck,
Is it really 15" in diameter ? I thought that on the Roadster it was 16" like on the last Plus 8's.
BR.
Daniel.
Vampirex #44591 16/05/10 04:53 PM
Green & Grown Up
Green & Grown Up
You are right Daniel, they are 16" - again my enthusiasm to post lets me down doh
Hi Franck,
I had the idea that the so small gap you have between the tyre and the rear panel was about that. But I checked on my Plus 8 so the size is 205/55R16, and my gap is the same as Andy's car.
BR.
Daniel.
Vampirex #44651 17/05/10 09:52 PM
Green & Grown Up
Green & Grown Up
Originally Posted By Vampirex
I checked on my Plus 8 so the size is 205/55R16, and my gap is the same as Andy's car.Daniel.
Daniel - Now you have embarrassed me into actually measuring the gap. It is exactly 1.5cm all around.
I suppose I could offset the wheel slightly to increase the gap at the top to 2cm ish coffee .
What is you actual tyre size (width/aspect ratio) Frank?
Cheers,
Franck, I measured mine too and it is between 2,5 and 3cm. You don't have a large capability to offset because of the centre which has only one place and the "tee" has to be exactly in front of the hole to be tightened.
BR.
Daniel.
