10 members (Gramrugby, ajsms999, 2949olivier, MJF, BLUE+4, deano, paulmog, Ncik P, GrumpyPa, jbk),
194
94
Topics49,871
Posts837,677
Posts: 367 Likes: 1
3rd Brake Light
My solution to the Issue. DIN socket mounted next to the Cobra head and spliced into loom inboard of the existing connector
Posts: 3,727 |
What is you actual tyre size (width/aspect ratio) Frank? Cheers, Hi Graham, Not sure what aspect ratio is??? Markings on my tyres : Avon ZV5 205/55R16 91W Standard Load Treadwear 300 Traction A Tempurature A Tubeless. There are quite a few other numbers & letter but I have no idea what they are for?
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Hi Frank: 205/55R16 Width across tread: 205mm Aspect ratio 55% i.e. sidewall is 55% of the tyre width or a bit over 110mm R = radial 16 is wheel diameter  Now you know! So, if Andy's tyres are the same - the hole for the spare in your tail panel is smaller than his... Cheers,
Posts: 3,727 |
Thanks for the Info Graham. As Benny Hill (bless him) used to say 'Learning all the Time'
