8 members (MartO, Ruut Bianchi, planenut, gmcn, SailingTom2, BLUE+4, Robbie, KennethM),
315
42
Topics49,917
Posts838,223
bespoke 2012 plus4 dash
EventuallyI got my bum into gear and ventured to share photos of my homemade dashboard. If the uploading works I will add descriptions. The weather here is most depressing and the roads are full of hostile salt. The Morgan will have to stay in  So much for now, Michael
Posts: 27,853 Likes: 767
Posts: 27,853 Likes: 767 |
Posts: 6,538 |
Looks v smart indeed. Nice piece of wood - makes all the difference.
Well done!
Neil
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
Well done! +1 Would like to change mine too. Looking forward to your descriptions.
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
Ooh interesting. What was the driver behind doing this? Was it an issue with the existing setup? Are you using the existing relays.?
Looks very good....
Nick
Posts: 12 |
Thanks!
Hopefully the photos posted seperately explain some issues.
I've read everything about dashboards in this forum over the last 6 months – thank you very much!
The first thing was to make up my mind about which instruments, lights and switches I wanted to install.
Instruments I ordered from Caerbont – the Flight series is similar to the existing Speedo and Tachymeter, practically anything could be made to order, however.
The wires I ordered from Amazon, the warning lights from europaspares.com and the LED bulbs from a lokal electronics supplier or Amazon. It was great fun receiving new parcels every day.
Then I had to decide which surface it should be: I chose a black leather in contrast to the existing walnut dash after having tried a few versions of stained and varnished veneers.
I then bought a 5mm beech plywood, which is very simple to jigsaw and tough enough to withstand all acting forces. It is cheap and I can change the layout any time just by jigsawing another board.
The challenging bit was to test the correct wiring of the warning light PCB, to solder the switches off the main PCB and to solder them on again with flying wires.
It is all very straight forward and analog – just give it a go. I practised soldering on an old computer PCB previous to working on the real thing.
Michael
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Really nice
Glad you got your bum into gear !
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
Looks great - well worth the effort.
