8 members (MartO, Ruut Bianchi, planenut, gmcn, SailingTom2, BLUE+4, Robbie, KennethM), 315 guests, and 42 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,917
Posts838,223
MossyfromNZ
#489347 17/12/17 11:34 AM
mise303 Offline OP
bespoke 2012 plus4 dash
EventuallyI got my bum into gear and ventured to share photos of my homemade dashboard. If the uploading works I will add descriptions. The weather here is most depressing and the roads are full of hostile salt. The Morgan will have to stay in gloomy So much for now, Michael
8 Comments
Very tasty
Looks v smart indeed. Nice piece of wood - makes all the difference.
Well done!
Neil
Well done!
+1
Would like to change mine too.
Looking forward to your descriptions.
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
Ooh interesting. What was the driver behind doing this? Was it an issue with the existing setup? Are you using the existing relays.?
Looks very good....
Nick
mise303 Offline OP
Thanks!
Hopefully the photos posted seperately explain some issues.
I've read everything about dashboards in this forum over the last 6 months – thank you very much!
The first thing was to make up my mind about which instruments, lights and switches I wanted to install.
Instruments I ordered from Caerbont – the Flight series is similar to the existing Speedo and Tachymeter, practically anything could be made to order, however.
The wires I ordered from Amazon, the warning lights from europaspares.com and the LED bulbs from a lokal electronics supplier or Amazon. It was great fun receiving new parcels every day.
Then I had to decide which surface it should be: I chose a black leather in contrast to the existing walnut dash after having tried a few versions of stained and varnished veneers.
I then bought a 5mm beech plywood, which is very simple to jigsaw and tough enough to withstand all acting forces. It is cheap and I can change the layout any time just by jigsawing another board.
The challenging bit was to test the correct wiring of the warning light PCB, to solder the switches off the main PCB and to solder them on again with flying wires.
It is all very straight forward and analog – just give it a go. I practised soldering on an old computer PCB previous to working on the real thing.
Michael
Top work.
Really nice
Glad you got your bum into gear !
Looks great - well worth the effort.
Costock, UK
Disco 5
