8 members (Guten, Chris Cosher, Ian Wegg, Deejay, BobtheTrain, sprinty, DCH, Andrew255),
315
67
Topics49,850
Posts837,433
Posts: 922 Likes: 1
Your thoughts? - Tonneau for a four seater
We have been attempting to fit the Tonneau with varying success, yesterday it went on using the method described in the video found here: https://youtu.be/HCS-VoYdMIEThe method is the same for a four seater As you see ours is not quite on properly, the hood material needs tidying and one or two of the poppers still have to be stretched into place. By the time we had finished both of us were exhausted, it took us a good 20 minutes and so I think this is not something we will be doing very often. I must say that driving with it fitted over half the cockpit is rather special and I imagine it could be very cosy in winter. I would be interested to hear of your thoughts on the use of this item.
Kevin
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
It's not nicknamed 'neverflex' without good reason
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Fitting a tonneau cover.... Thank you😉
Posts: 528 |
We have been attempting to fit the Tonneau with varying success, yesterday it went on using the method described in the video found here: https://youtu.be/HCS-VoYdMIEThe method is the same for a four seater As you see ours is not quite on properly, the hood material needs tidying and one or two of the poppers still have to be stretched into place. By the time we had finished both of us were exhausted, it took us a good 20 minutes and so I think this is not something we will be doing very often. I must say that driving with it fitted over half the cockpit is rather special and I imagine it could be very cosy in winter. I would be interested to hear of your thoughts on the use of this item. The "Cover for the Tonneau area" (Iwith respect from one Ian to another Ian  You know who you are! ) is a great enhancement when driving solo and for security when parking. The video is spot on and it takes (normally) two minutes. By fitting and securing the front poppers with the hood frame raised takes all of the tension out of the cover and then retentions when hood frame locked down. However, once fitted and you are driving alone it can inflate and flap around (particularly without side screens). I found it unpleasant and noisy so I came up with a cheap and easy modification. See thread http://www.talkmorgan.com/ubbthreads.php/topics/498988/1regards Ian
Posts: 922 Likes: 1
Posts: 922 Likes: 1 |
One of the joys of touring in Morgans is watching the four seater guys fit hoods or tonneaus at the end of the day whilst one is imbibing on a refreshing ale. I have often found that giving some advice also makes it more fun for all concerned.  Good luck. I am sure the four seater owners on here will put you right Glad to be of service John
Kevin
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Just to help Kev
A few ideas that I’ve used that might help
Leave the cover on and park it in the warm sun for a bit and then try again to get the poppers on or if you want to do it in the garage apply a bit of warmth with a hair dryer - (warm not hot) to help it stretch a bit and do a bit of tucking again
Once it’s on apply some Aerospace 303 Protectorant. This helps to stop UV fading and shrinkage and cleans it as well
If you leave it on a few weeks while you are motoring it soon complies a bit more
Even though my cover is Mohair, it is trimmed all around the edge with vinyl so mine is always tricky to put on the first time in a while and I have the same problems
Posts: 3,695 Likes: 131
Posts: 3,695 Likes: 131 |
The "Cover for the Tonneau area" (with respect from one Ian to another Ian  You know who you are! ) ... Thanks Ian for keeping the flame alive! Here's another little helpful link for the OP ... To Know Tonneau
also Kev
Just a thought on storage of your cover when it’s not in use
I have mine folded in a bag stored in the warmest part of my garage It’s an integral garage and the corner next to an internal wall at the back of the garage is pretty warm from the house all year round. This helps a bit.
If your garage is separate and/or unheated, it might be better storing it in the house
I also have a hood cover that looks identical to the back bit of the tonneau cover and I do the same for that as well but it’s always a struggle putting it on after a long time stored
Posts: 1,103 Likes: 17
Posts: 1,103 Likes: 17 |
The new seater tonneau is a pain to put on.. I wondered if you could add a zip so you have a hood cover and a tonneau?
The challenge is getting the tonneau under the hood frame at the back.
I have a mohair one in my dads car which is no better.
Posts: 28,899 Likes: 352
Posts: 28,899 Likes: 352 |
The "Cover for the Tonneau area" (with respect from one Ian to another Ian  You know who you are! ) ... Thanks Ian for keeping the flame alive! Here's another little helpful link for the OP ... To Know TonneauEver feel like you are  Ian. There are many who will never get it!
Posts: 5,465 Likes: 171
Posts: 5,465 Likes: 171 |
I have a mohair one in my dads car which is no better. I had a new tonneau cover made by Allon White with a transverse zip. We use it when touring as it has a flap that ensures all the luggage is covered and we just zip on the front part when parking. The zip isn't fully waterproof - I decided against flaps etc because of where it is - but it serves a useful purpose for summer tours.
