1 members (Alastair), 319 guests, and 37 robots.
+8Rich 94
Posts837,276
#690772 26/02/21 03:29 AM
1955er Offline OP
Checking gear box oil
Searched everywhere for gear box oil fill/level plug.....is this it? I didn’t imagine it would be accessible from under the bonnet but checked for access in sides of trans tunnel and no luck.
Neil.
Ps mmmmm pics not showing in preview so fingers crossed.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
6 Comments
You need to take the "e" out of ;jpeg Neil.
1955er Offline OP
Thx Graham but how? At source? Ie my computer?
Yes, before uploading. Edit the photo name so the extension reads ".jpg" for JPEG files and save the file.
It is a "feature" in the forum software. In the earlier days when file extensions could only be a maximum of 3 characters the default extension name for files of this type was .jpg smile
Hope that helps.
TBM Offline
On my 1972, the gearbox filler is on the right/drivers side of the gearbox. There's a cut away hole in the transmission tunnerl near the clutch pedal, with a standard four sided filler plug.
I've had seen others where it is on the opposite side!
If it's a 5 speed type 9 mine's on the passenger (left) side at the front near the bellhousing.
1955er Offline OP
Thx Graham . will start from scratch on the lap top as can't do it on ipad for some reason.
Cheers, neil.
