2 members (gomog, Hamwich), 392 guests, and 74 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
#717166 07/09/21 03:37 PM
4 Images
ebetec Offline OP
M3W Austria
...next improvements:
suspension upgrade from krazy horse - thanks again to Nobby from KH for the great support!
MMC steering comfort kit
MMC urban cooling kit
new position of voltage regulator
...and a lot more you don´t see from outside smile
and finally the best thing - the new wind screen from m3w service in france - version: SPORT PLUS MODEL
If you are interested in the wind screen contact M3W service in france directly
Eddy
built not bought - hustled not handed - earned not given - rare not average
6 Comments
ebetec #717169 07/09/21 03:41 PM
ebetec Offline OP
... the new feeling to drive the M3W is incredible - fantastic steering behaviour now. The 3 wheeler is doing now exact what it should do and there are no more bumping shocks in the steering wheel during driving on bad streets!
Eddy
ebetec #717303 08/09/21 01:16 PM
Gosh, driving it must be like night and day compared to before!
As a matter of interest, what are the suggested settings for the Empire kit? I'm thinking particularly of camber & caster settings.
Andy
Bunny #717365 08/09/21 07:29 PM
I mean the settings as recommended by Krazy Horse.
Andy
ebetec #717406 09/09/21 08:10 AM
ebetec Offline OP
in the instruction manual from KH you find a small range of possible adustment
1 degree of negative camber
6-7 degrees of caster
... and YES - driving it now is a total different experience - in the next 2 months I should receive a set of Oehlins for the M3W ... with this I can´t do more improvements for the driving performance
In the winter time I will change the rear tire to an 175/70 R 15 Avon CR 6 ZZ racing version with approval for normal use on the street.
Eddy
ebetec #717408 09/09/21 08:20 AM
Hallo Eddy!
A further improvement I can recommend is sealing the tonneau against dust from the rear side of the M3W.
All you need is self adhesive neoprene or something similar.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
ebetec Offline OP
Originally Posted by The Austrian
Hallo Eddy!
…Servus nach Wien 😉
My first work was to seal everything inside the passenger area, additionally I installed ~15 kg of anti vibration plates inside this area.
A good description for this job can be found here (for those who want to do something similar):
https://www.speedymarmots.com/hangar-works-18-soundproofing-and-sealing-the-cockpit/
Eddy
