4 members (DPEvans, Steve +8, CooperMan, ScottMellor), 229 guests, and 62 robots.
+8Rich 97
Posts837,260
#793936 16/01/24 10:55 AM
sewin Offline OP
jack stands
Jack stands I made to support the cross head/axle when using a lift or stands
19 Comments
sewin #793937 16/01/24 10:58 AM
sewin Offline OP
Sorry just can't get these pic's to attach to my description in the post!
sewin #793967 16/01/24 08:22 PM
Not sure why but here you go.
sewin #793979 17/01/24 07:42 AM
Not sure why...
Referring I think to the OP's "Jack Stands" thread in the Soap Box section. smile
sewin #793980 17/01/24 07:57 AM
Thanks Graham although an odd place for such a post. Getting workable image links from the Gallery seems to be flaky at best. I get the picture to display full size, open it in a fresh browser tab then copy that link. Far better to not use Gallery at all but instead an external picture hosting site.
sewin #793996 17/01/24 11:11 AM
sewin Offline OP
Yep Richard you're absolutely right, I hadn't intended to post in soapbox but when I pressed post the damn thing all disappeared, later I discovered that it had appeared in soapbox and I couldn't move it to maintenance. so I gave up! probably All my own fault and a result of preferring spanners to keyboards!
sewin #794007 17/01/24 01:48 PM
Not sure why you need them?
A pair of axle stands would do just as well?
Arwyn
2 members like this: gomog, Taffmog
Arwyn
As Arwyn stated standard axal stands would be better and also safer, because the footplates of the stands appear very small. If you were to use a trolly jack to raise the rear end of the car with the crosshead lifted up onto your stands, the radial lifting action of the trolly jack would drag the crosshead stands over
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
sewin #794017 17/01/24 05:39 PM
TBM Offline
If you read the other thread, it's to support the crosshead while using a hydraulic lift - the kind that lifts from the chassis rail. Quite a niche usage!
sewin #794955 01/02/24 03:19 PM
sewin Offline OP
Thanks TBM,
No I wouldn't dream of using them to support a vehicle as stand alone (axle)stands as quite rightly they do not have a base designed to
Support a vehicle that could move and of course their minimum height with the top tubes shown is around 600mm. rather they are for added support when working at lift height, I have shorter tubes for a lower height say with axle stands.
My intended use was for added support under the front crosshead when the car is staying on the lift for a prolonged time or working on the rear end when on a lift ie. supporting the rear axle.
