6 members (SteveT, Craig Jezz, MJF, scortroadster, Luddite, Sir Percival), 324 guests, and 102 robots.
Sagging Hood
Topics49,859
Posts837,479
shiremog #111046 10/11/12 10:04 AM
Most of my fillings have shaken loose driving the Morgan, I wouldn't be surprised if a relay had come loose from its moorings. smile
+8 4.8
Neilda #111055 10/11/12 12:21 PM
Sometimes you get a bad contact on electrical components due to too high a resistance in contamination of the surface of contacts. I have never understood what it is but it used to be a common practise to clean the edge connectors on computer boards with a clean ink eraser before replacing a component. It is amazing how often it works. Since learning that trick I have removed and replaced motorcycle relays and ECU connectors two or three times to rub the contact surfaces together and ensure good contacts before rushing for a replacement.
Gambalunga #111157 11/11/12 09:29 AM
Fretting corrosion is a form of accelerated atmospheric oxidation which occurs at the interface of contacting materials undergoing slight, cyclic relative motion. In electric contacts involving non-noble metals, fretting action can cause rapid increases in contact resistance, proceeding to virtual open circuits in a matter of minutes in the worst cases.
Now you know
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #111164 11/11/12 10:42 AM
Very interesting. Thanks for that Neil.
I did some research on the topic and it is nice to know there is an explanation for what I have been doing. Seems it can be caused by even minute movement due to vibration or differences in thermal expansion.
It also makes me realise that there is a good reason for oiling the body joints (as recommended) on our Morgans. I wonder if that explains some of the corrosion and paint bubbling around fittings and joints, particularly on the Aero series.
Gambalunga #111175 11/11/12 01:09 PM
I think you hit the nail on the head with regard to vibration. its probably more critical in a Morgan where the cars do tend to bounce around a fair bit. Perhaps the old fashioned method of screws on terminals is not such a bad idea. Of course it's less time consuming to have push in contacts when building a car. On the other hand it's much easier to change a component if required.
The bubbling problems could be caused by a multitude of reasons including reactions to different type of metal. It's interesting that on a boat you have a sacrificial anode on the hull to stop corrosion. This I understand is caused by electron reactions. Not sure an Aero would look quite right with an anode trailing behind the car. smile
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
NeilM #111271 12/11/12 12:04 AM
This opens a up a whole new are for MMC to charge for on the extras list....
Giles. Mogless in Paris.
pandy #111358 12/11/12 04:18 PM
I had a sacrificial anode bar in the door of my Triumph Herald in 1969. Unfortunately the whole car rusted away leaving only the doors! It took about 3 months.
nick
NeilM #111810 17/11/12 04:48 PM
I'm with you professor read electrolytic reaction me thinks ?
Graham
TRMAN #111823 17/11/12 06:07 PM
I spray my critcal contacts every 2 years with contact cleaner when I also waxoyl the body.
John V6 #112153 19/11/12 07:13 PM
That sounds extremely painful - Is it a know medical condition rofl
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
