Morgan Aero 8
4 members (RedThree, nick w, Plus Four Guy, Pundit), 210 guests, and 64 robots.
+8Rich 79
DaveW 51
Topics49,866
Posts837,587
#11251 16/11/07 08:37 AM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Looking at my Aero (as I do occasionally) it looks very undertyred. The tyres seem to be stretched somewhat.
Is it possible to fit wider rubber?
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #11266 16/11/07 02:54 PM
Some tyre manufacturers come up wider than others for the same size, just depends on the design... you can fit wider tyres on the Aero.. the measurements can be found on the net somewhere...
You'll need the Rim width from OZ then cross reference against the tyres you wish to use to see if that width can be used. These are published in tables on the tyre manufacturer's web-site.
I think you can fit upto 18' 245's on the OZ rims if you use the Yokohama A048's but go too wide and you end up needing to shave the wheelarch.
Which ever route you take always follow the tyre and wheel manufacturer guidelines. (I know that's a bit obvious, but worth saying anyhow.)
kin Offline
On S3, 245's fitted as standard....
kin #11280 16/11/07 04:37 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
When going wider i know I'll need to keep the rolling radius the same by lowering the aspect ratio.
I didn't know if there was any clearance issues on the inside edge...Inner wing.
Be interested to know if anyone has done so.
2002 Aero 8 S1
