Morgan Aero 8
6 members (Julian BB, Chris Cosher, Grumpy2, DazMog, JohnHarris, Hamwich), 257 guests, and 80 robots.
+8Rich 77
Topics49,870
Posts837,669
Rudolf
another Offline OP
Hi
My battery is flat- spoke with Factory yesterday and want to buy both new battery and a trickle and charger in one. Found this
http://www.ctek.com/EN-GB/MULTI-XS-3600.aspx
CTEK Multi XS 3600
Four step, fully automatic switch mode model.
Charges lead-acid batteries (Wet, MF, GEL and AGM) from 1.2Ah to 120Ah.
Maintenance pulse charging increases battery life and gives superb performance.
Charges even drained batteries.
Pulse recover of slightly sulphated batteries.
Three unique charging modes for use on small batteries, large batteries and a special cold mode that is also suitable for AGM batteries.
Low back current drain, low ripple and input voltage independent (170-260V).
High efficiency: 85%
Delivered with two interchangeable connection leads, one with clamps, and one with eyelet terminals.
The charger can by connected for months, ideal for seasonal vehicles.
Compact design with mounting holes for permanent assembly.
5 year warranty.
Anyone got one or a better charger to recomend- want to buy for the weekend!
Thanks Roger
Mr Fezza
Mr Fezza
Looks pretty good and beats my knackered oldd contraption into a cockedd hat.
What does it cost?
Maxxed out!
I use one too mr_tony through the cigarette lighter and can't recommend it highly enough. I bought mine at a car show allegedly at a discount price, but for the life of me can't remember what I paid for it. oops grin2
Brian
2014 Morgan SP1 (Rocket Red)
Used that exact one on my Plus 8 and never had an issue thumbs
Got mine from http://www.hamiltonclassic.co.uk/
Phil Egginton
1979 4/4 4 seater
Mr Fezza
Mr Fezza
Mine works (through cigarette lighter) and it's very small (size of a mobile phone charger) - doesnt' ahve all the fancy features though!
Maxxed out!
I use the sameone. I have a special cable & fuse to the battery woth thier special plug
Works great on my +4
U
TM Photographer of 2008
U
I have an AccuMate 6v/12v charger which seems to do the trick. My only criticism would be that getting a good connection through the cigarette lighter socket can be a pain.
http://www.accumate.co.uk/it010001.htm
Ken
I too have a Ctek 3600. When checking the cig lighter socket I found it had never been connected! It is now...
I'm also a user of Trickle Chargers, either Brand will do the same job. Have a 'cheap' Supermarket Brand one installed on the 'Ride - On' Mower over winter and it does it's job admirably. Presumably, the more expensive one currently 'running' on Arian in her 'Mogtel' will last longer(?)
another Offline OP
Thanks all will purchase then....
