4 members (DavidR, MATTMOG, Bishmog, MogOnTheMove), 379 guests, and 32 robots.
Adam12 69
+8Rich 68
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,389
Members9,215
Rbt Aero8, Salmon, stevends
Page 3 of 4 1 2 3 4
E
E
Further to this - Milton Racing supply an adaptor plate to mount a Type 9 5 speed box to your original Ford 4 speed gearbox bell housing, you can then keep the starter in the same position and retain the hydraulic external slave cylinder.
1989 911 Porsche Carrera
Land Rover Series
Defender 90 SW
That's handy to know.
What about cable and rod operated clutches? Both are on Morgans...
'09 Gen2 MINI Cooper ragtop
E
E
Not too sure about rod operated Graham but you can no doubt rig up a cable clutch. I'm not really a fan of cable operated clutches hence I'm keeping the hydraulic external slave cylinder. Retro Ford do a bellhousing and concentric slave cylinder if you prefer that set up.
Land Rover Series
Defender 90 SW
OK, thanks.
Mine has a cable clutch and the 4/4/4 I'm hoping to acquire (presently engine out) is rod operated. Did think it would make sense to look at a gearbox swap as the car is partly dismantled anyway... smile
Is the cable clutch on yours original or has it been modified? I ask because the rod operated item is a pig to adjust and I've often thought about doing the conversion.
1972 4/4 2 Seater
Cable on a '76
The 4/4/4 I mention is a '73 (not mine yet - but it's the first Morgan I sat in). Not sure how long rod operation was used, but I seem to remember somewhere pre-'71 it was cable operation. Rod operation only came in for a few years, before returning to cable...
I prefer hydraulic, but having said that, I've had no problems, so far, with my cable operation (I do carry a spare though - a foible from my TVR days! smile )
A "4/4/4" Graham?
I was told by John Worral recently (he supplied me a spare clutch cable as I thought I should have one on the shelf)...
-Quote-
the earlier pre 76 Kent engined cars used the Clutch Rod system..they changed to a cable when Power Torque modified the Bellhousing prior to delivery
-End Quote-
E
E
My 1969 4/4 with the X Flow Kent engine has a hydraulic clutch; the slave cylinder mounts to a cast-in bracket on the bellhousing on the passenger side and pushes the operating rod backwards towards the bulkhead.The slave cylinder is a Mk 2 Cortina item and is quite expensive if you need to buy new or re-manufactured.
Land Rover Series
Defender 90 SW
4/4 with 4 seats J! smile
Page 3 of 4 1 2 3 4
