0 members (), 256 guests, and 94 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
#116487 20/12/12 06:02 AM
Just took the glass off the side lights on my 4/4 and only one screw holding. The bottom screw devolved to a block of rust. Both front lights are the same and I presume the back lights will be. Is there a replacement stainless steel version for these lights. The bulbs are also corroded in.
Thanks
Phil
Regards
Phil
2001 4/4 Red
I am not aware of any alternative than the Lucas unit. I suggest you get replacements and this time ensure the lens is well sealed to the light unit. Might even be worth using the rubber gasket from the old ones as an additional one with the new (not tried this myself, I use sealing gum that they use on caravan panels)
Keith
