1 members (mph),
225
40
Topics49,844
Posts837,360
Posts: 8,646 |
We once insured our son's bike when he went to Uni as a miscellaneous bicylce. It got nicked & when we claimed were told we should have specified the miscellaneous bike.
Was it not a Unicycle ?
Giles. Mogless in Paris.
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
1972 4/4 2 Seater
Gone to Porsche Part of the Furniture
Posts: 4,333 |
F inancial- I mmoral- C unning- A ffiliated- L iars Liars? I can see my dyslexia is bothering you T !!! as i failed miserably at school in English i consentrated more on maths, as some one informed me there were only 10 things to concentrate on 0-1-2-3-4-5-6-7-8-9, it seem to work as the Bank balance is fine  My new i phone is even worse than me, it predicts to much, i end up pressing the send button far to quickly, and you can't bloody stop it once its on its way.
F inancial- I mmoral- C unning- A ffiliated- L iars Liars? I can see my dyslexia is bothering you T !!! as i failed miserably at school in English i consentrated more on maths, as some one informed me there were only 10 things to concentrate on 0-1-2-3-4-5-6-7-8-9, it seem to work as the Bank balance is fine  My new i phone is even worse than me, it predicts to much, i end up pressing the send button far to quickly, and you can't bloody stop it once its on its way. Fair play! I was hoping for another acronym.
1972 4/4 2 Seater
Posts: 4,333 |
Acronyms, wern't they invented for teenagers to TXT one another
Acronyms, wern't they invented for teenagers to TXT one another You're a legend!
1972 4/4 2 Seater
Posts: 407 |
That's not an acronym, it's an abbreviation.
Posts: 1,502 |
As in pdnt?
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
All very ingenious, but you can buy a 12V Cigar Lighter Plug, with a built in USB port. I have used the 12 V Plug to power the GPS while using a USB cable to charge the mobile phone. Only 1 12V Port needed.
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
The problem is that a lot of the chargers are not a good fit in the 12V cigar lighter plug. Unfortunately there are two standards for cigar lighter plugs, this often means poor connections. Naturally they were never really intended to be used as power sources. A decent USB socket will always give a good connection. 12-volt cigar lighter receptacle and plug, size A
Receptacle inside diameter: 20.93 - 21.01 mm (median 20.97 mm) Plug body diameter: 20.73 - 20.88 mm (median 20.805 mm) Most often used in American automobiles.
12-volt cigar lighter receptacle and plug, size B
Receptacle inside diameter: 21.41 - 21.51 mm (median 21.455 mm) Plug body diameter: 21.13 - 21.33 mm (median 21.18 mm) Most often used in European automobiles, and sometimes as a second socket in American automobiles expressly for DC power connections. For more information see http://en.wikipedia.org/wiki/Cigarette_lighter_receptacleA better plug for power applications and charging is the ISO 4165 connector but it is more difficult to find adaptors for this type of socket.
