Topics49,841
Posts837,316
Posts: 472 |
shiremog: I will listen for the squeak - what kind of grease and what method do you use when greasing your bushings? I used moly grease. My Roadster didn't have the oiler, just a single grease nipple on each side. The current Roadster has 2 nipples on each side, one at the top of the king pin & one on the hub, so more work to service this one  I've also fitted gaiters over the springs to keep some of the weather off the king pins. Ian Thanks - I have used white moly spray after cleaning the kingpin under the rebound spring and it seems to work, so far. The biggest problem is in the lower end I think...
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS -04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Posts: 472 |
I use castrol cl grease as it is designed to be water resistant & for older style suspension systems. Hi John, I found some new info regarding Devol bushings on the GoMog site. I also think water resistant (or water repelling) grease could be good to use with the Devlon bushings - Has anyone tried it before?
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
I don't have devol bushes but surely someone has
Posts: 534 |
My last Roadster had plastic bushes. Is that the Devol? Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
Posts: 28,891 Likes: 350
Posts: 28,891 Likes: 350 |
Yes...
Posts: 472 |
Hi, I have heard that it is customary to publish a picture or two - here's my car (still English plates):   If you think the windscreen looks a bit 'unusual' (?) - you're right, it's a four seater wind screen (bespoke).  At home in Sweden:
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 472 |
Thanks - I think so too
Posts: 541 |
I agree, it would be nice to see your car in Denmark in June! Ken in Sweden
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 486 |
Looks nice congratulations
Cain
Wolf Cafe Racer 4/4 Sport
