7 members (Robbie, Burgundymog, Sir Percival, gaston, SteveD, jbk, TalkMorgan), 346 guests, and 54 robots.
+8Rich 92
Topics49,837
Posts837,286
Page 3 of 17 1 2 3 4 5 16 17
Lecat Offline OP
Originally Posted By shiremog
Originally Posted By Lecat
shiremog:
I will listen for the squeak - what kind of grease and what method do you use when greasing your bushings?
I used moly grease. My Roadster didn't have the oiler, just a single grease nipple on each side. The current Roadster has 2 nipples on each side, one at the top of the king pin & one on the hub, so more work to service this one innocent
I've also fitted gaiters over the springs to keep some of the weather off the king pins.
Ian
Thanks - I have used white moly spray after cleaning the kingpin under the rebound spring and it seems to work, so far. The biggest problem is in the lower end I think...
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat Offline OP
Originally Posted By John +4
I use castrol cl grease as it is designed to be water resistant & for older style suspension systems.
Hi John, I found some new info regarding Devol bushings on the GoMog site. I also think water resistant (or water repelling) grease could be good to use with the Devlon bushings - Has anyone tried it before?
I don't have devol bushes but surely someone has
My last Roadster had plastic bushes. Is that the Devol?
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
Yes... smile
Lecat Offline OP
Hi, I have heard that it is customary to publish a picture or two - here's my car (still English plates):
If you think the windscreen looks a bit 'unusual' (?) - you're right, it's a four seater wind screen (bespoke).
At home in Sweden:
Great looking car....
Lecat Offline OP
Thanks - I think so too smile
I agree, it would be nice to see your car in Denmark in June!
Ken in Sweden
Ken in Sweden - SM7CQY
Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Looks nice congratulations
Cain
Wolf Cafe Racer
4/4 Sport
