0 members (), 309 guests, and 37 robots.
Topics49,860
Posts837,486
Jonny72
Page 3 of 4 1 2 3 4
DaveW #118867 09/01/13 06:46 PM
Neil, if Dave W took two days to drill then you know its going to be a very difficult job. If you have any of the stud left as a slight raised portion then when you start to drill the drill will catch on the raised portion and the drill will wander resulting in a scratch, I doubt masking tape around the area will save you. You could very easily do more damage without hardly trying. You will need to flatten the surface, maybe using the dremel, but take your time and be careful, then use a centre punch to locate the centre of the stud before you drill, the centre punch will locate the drill and stop the drill from wandering, start with a very small drill and make the hole larger if you need to. The stud/screw extractors are a very good tool, they work well. My advice is, unless you are very confident in what you are doing, take the car to the dealer and go and have a coffee while they take the stud out, its going to be like going to the dentist for a filling, don’t even watch, its going to be painful. Good luck.
Jeff
2009 Black & Tan +4
solomog #118869 09/01/13 07:00 PM
You can fix a repair washer over the stud with double sided tape as protection, providing it has a small centre hole.
Or use a metal screwcap with a small hole drilled in the centre. The edges should hold a wandering low speed drill!
solomog #118873 09/01/13 07:29 PM
My suggestion to use masking tape to protect the paint was predicated on careful use of a Dremel cutting disc to cut a slot in what I had understood to be an exposed 2mm section of protruding stud and protecting the paint from any sparks that may be generated. Clearly, masking tape would provide no protection from a "wandering drill bit"... for that DaveW's suggestions above would clearly be better options.
Philip.
MonteZooma #118900 10/01/13 05:38 AM
Dave W, brilliant suggestion .... I am a fan!
Jeff
2009 Black & Tan +4
solomog #118909 10/01/13 07:09 AM
Morgan root canal work...... rofl rofl rofl
Easter #118921 10/01/13 09:48 AM
Neilda Offline OP
More painful thank that! smile
+8 4.8
Neilda #118927 10/01/13 10:34 AM
Neilda Offline OP
I've bought some very fine (0.5mm) drill bits for my Dremel - so I might have a go.... What bit would I need to engage with and unscrew the sheared stub? I assume its tight I'm there from the factory fitting.
+8 4.8
Neilda #118928 10/01/13 10:39 AM
Are you sure about this? Sounds like the recipe for lots of additional swearing.
swear
I think I would leave it to BHM to sort it, or alternatively you could P.Ex the car for a new +8?
Bud
__________
2003 - 4/4
Bud
4/4 "Stanley"
Budster #118968 10/01/13 04:15 PM
Neilda Offline OP
You could be right Bud. I'll ask BHM if they can remove studs..... I can't quite see their big hairy mechanics fiddling with such a little thing! smile
I'm not totally sold on the 8, which is why I bought the Roadster. I took an 8 out last year and felt it was too much power for a car I just wanted for country lanes. I have 600bhp monsters for blasting. smile
+8 4.8
Neilda #118984 10/01/13 06:14 PM
Start very fine. The trick is to get a hole started, then you can go bigger, but protect the paint first.
Don't generate too much heat - nice and easy. The metal is quite soft so once you're in, it will drill well. Bear in mind that the stud may not be in square. Mine was angled down slightly.
Easter is right, a dentist could breeze this job.
Page 3 of 4 1 2 3 4
