3 members (Beard, sprinty, Alistair), 395 guests, and 39 robots.
+8Rich 92
Topics49,839
Posts837,301
Page 6 of 17 1 2 4 5 6 7 8 16 17
PJB Offline
Read page 3 of http://www.talkmorgan.com/ubbthreads.php/topics/131105/3
You can ask the dealers too who have driven the test car or Kevin Vernon at Tudor Vernon who has done two conversions.
Tim Harris who is on TalkMorgan is haveing his car done today Friday, so ask him too.
https://sites.google.com/site/morganatica/suspension/springs-progressive-rising-rate for dealers who fit.
Regards PJB.
Hi Titus and welcome to TM. Have a look at PJB's postings on the subject....he has them fitted and is involved in the development of them with Suplex. I've been out in his car and am impressed enough to get them fitted once I'm back from France.
PJB #131198 12/04/13 07:28 AM
Tim can occasionally be found on here, under the pseudonym Hamwich (the nickname for his 4/4) smile
PJB Offline
Titus, I have my 1986 4/4 2.0 litre so fitted with the SUPLEX kit, it is the test car. At least we are both in the SW of England, I am near Bath. So if you are ever up this way, then get in touch then you can try the car. Regards PJB
PJB #131228 12/04/13 10:36 AM
Thanks for the info and offer PJB. I am replacing the rear springs
after suffering sagging. I have removed the old ones and about to fit the new ones from Peter Mulberry along with his Panhard rod. As I am in suspension mode, thought an improvement in the front would be worthwhile. The opportunity to try one is great PJB. I will be in touch.
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
HI All
I spent a great day up at Tudor Motors, Kevin Vernon's place in Market Drayton, where we fitted one of the new Suplex rising-rate suspension conversions to the front of my 1986 4/4. The kit comprises springs, shock absorbers, radial thrust bearings, adjusting collars, and spacers. The idea is that you use the adjuster to make sure that the ride height stays the same and the rebound spring remains just free - the adjustment allows the kit to deal with a wide range of car weights.
Installation is very easy. Strip out the old suspension, bung in the new rebound spring, the spacer, the radial bearing, the dinky little spring that grips the top of the kingpin, the main spring,and the adjusting sleeve. Then bolt it all up together and set the ride height. The instructions are very clear and straightforward, the way they suggest the installation is done should be pretty foolproof, if a little time consuming. Because we had the car jacked up on the 4-post lift, it was very easy to set everything up without fitting the wheels until right at the end, making access very straightforward.
And the result? Well, I knew that the developers of the kit certainly knew their suspension systems, but nonetheless the outcome is frankly little short of staggering. On smooth roads there's really not much difference over the standard setup, but on bumpy backroads, or indeed anything less than motorway/trunk road quality surfaces, the suspension just soaks up the humps and bumps. There's no harshness, no crashing, no pitching or nodding. What's really impressive is that the revised front suspension complements the rear much better than before, with the result that the car remains much more composed - definitely a harmonised package (I have the later 4-leaf rear springs, with Panhard Rod and Anti-Tramp bars).
I put the car through some pretty extreme tests on the extensively potholed backroads around Market Drayton, including one stretch we found where the road surface had been scarified off to a depth of a couple of inches, with hard steps down from and back up to the road surface proper, but only over half the carriageway, so one wheel was thudding down a couple of inches and then back up over a sharp lip whilst the other was just having to cope with the normal bumps that you find on unclassified backroads. The first time I did it, I had a fraction os a second's worry that I had overdone it (I was doing at least 40mph at the time). But no, the car just drove straight through smoothly, with no jarring whatsoever. Kevin and I looked each other in surprise, and then proceeded to repeat the exercise half a dozen times on the following scarified sections to prove it wasn't a fluke.
The price is not trivial, the kit is nearly GBP 600 + VAT, and of course fitting will require a few hours. I daresay you could rip through the job in a couple of hours, but what's the point? May as well take the time to clean out the stub axles properly, and use the opportunity to ensure everything else (tracking, camber, etc) are all set optimally. But in terms of a single simple upgrade that would transform the handling of just about any trad car, this has got to be worth considering. Kevin's only had the kits available for a week or so, and he's already fitted 2 sets, so expect strong demand - get your names down quick if you want him do you a conversion. Other suppliers are available, of course :-)
The usual disclaimer applies: I have no connection with Suplex or Kevin Vernon, apart from as a very satisfied customer.
Tim
Thanks Tim for a detailed review.
I'm pleased that it isn't just the designers who think it's the "dog's ......." I value your opinion, so, Thanks!!!
O.K Tim -- that does it --the piggy bank is off limits until it coughs up enough to buy a kit!!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
NGUNS!!
NGUNS!!
Nice write up. Much of the suspension talk goes over my head but that was well written and interesting for an amateur like me. smile
Cheers
BtG
Good write up, sounds as if it may have exceeded your expectations.
Ian
