1 members (ChrisConvertible), 133 guests, and 79 robots.
+8Rich 70
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,885
Posts837,856
Gyp
Page 2 of 35 1 2 3 4 34 35
At least I only have to wait until tonight... smile
I think the switch will be to isolate the inertia cut off
Morgan 4/4 Sport Competition
doh yes, yes yes!
Thanks Sprinty, should have thought of that, and the inertia switch is still there in the photos.
I did like Jeremy's suggestion of a Nitro switch though laugh
Philip.
Yep ROAD/RACE switch is for the fuel pump inertia switch.
Not worried about comparing the cost really, as Jeremy knows money is'nt really an object and I would still of had to spend money on a babydoll/supersport. but the 1600 was a good a starting point as you can get power out of it and the unit is very light.
In the class I'm entering you are not allowed to use anti-tramp bars frown but I will be using a panhard rod.
If I move up class in 2014 then anti-tramp bars will be fitted, but for now the holes were kept there to help to stop bufferting.
- Lawrie Mills(Chunkylozza)
Youtube - ChunkyLozza
Very nice project, indeed.
I guess there will also be some engine tuning involved.
On my 4/4 Sport (2009) I removed the air filter box in front of the engine and installed a K&N open air filter system ( K&N kit nr 57-0686 for Ford Focus II ) directly to the air inlet at the rear of the engine via an elbow duct together with a funnel just below the radiator and an air ducting pipe.
This save some weight and gives a nice induction and exhaust sound.
D'herde Bart
D'herde Bart
The car is going on throttle bodies and using the Omex ECU
Very nice project indeed.
In my 4/4 Sport (2009) I removed the air filter box in front of the engine and installed an open air filter system ( K&N kit nr 57-0686 for Ford Focus II) directly to the air intake at the rear of the engine via an elbow pipe together with an air ducting pipe coming from down under the radiator with an air funnel.
This modification enhances the engine breathing (I hope!), saves some weight and produces a nice induction and exhaust sound.
Cordially
D'herde Bart
So todays antics,new version of the billet gear lever, engine oil cooler mounted and began the fittment of the aluminium radiator.
Cordially
D'herde Bart
It is indeed a lovely project. Congratulations to Williams Morgan for supporting racing like this. I look forward to being on track with you!
