4 members (GrumpyPa, Morganmike, bmgermany, Ian Wegg), 295 guests, and 94 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
#132052 17/04/13 03:31 PM
E
eds Offline OP
E
I have a 2009 4/4 sport . Last week when driving home two warning lights started to glow but not fully on. The warning lights were for the handbrake/ brake fluid and seat belt. When I apply the handbrake the relevant light is full glow. As the seat belt light has never come on and, to my knowledge, there are no seat belt connections for it to be functional I am confused. The brake fluid level is on max. Any suggestions on what could be the problem ?
eds #132056 17/04/13 04:03 PM
On my 4/4 Sport the warning lamps glowed dimly if the electrical connector on the brake fluid resevoir got soaked
E
eds Offline OP
E
Thanks for the suggestion. Checked the electrical connector , looked dry, but still gave it a clean. Unfortunately the lights are still glowing dimly.
eds #132193 18/04/13 11:58 AM
sorry I've almost exhausted my knowledge of vehicle wiring, other than checking earth conections or signs of frayed insulation frown
E
eds Offline OP
E
This morning I ventured under the dash and had a closer look at the warning light cluster which, on the 4/4 sport, is a printed circuit with leds. Immediately I saw that the wire ribbon connections to the board were scuffed - rubbing against the dashboard. I cleaned them with a cotton bud and, success, no more glimmering lights. Before reattching the board I stuck some electricians tape over the connections to provide some cushioning. Just a warning, beware that the printed circuit connections will rub on the dash.
eds #141498 21/06/13 10:26 PM
Good tip. Thanks for sharing.
