6 members (AlyMatt, TrickieDickie, IcePack, David_E, PaulJ, DaveW), 268 guests, and 91 robots.
Topics49,849
Posts837,410
DazMog, The Impaler, tlchzj79
Wirewheel #134965 08/05/13 01:18 PM
I added a bit of mechanics wire tie to one clip as a safety feature as the front shake has popped mine before.
Gordon
Wirewheel #136431 18/05/13 09:41 PM
TRBOB Offline OP
Thanks for the help. I decided to go with the stone guards from CA. Expensive but unique. Edgar is right, they only work on flat lenses! Just happens I had a set. Here is a photo of how it turned out.
bob
[img:center]http://facebook.com/photo.php?fbid=49271...e=1&theater[/img]
TRBOB #524691 29/07/18 01:21 AM
TRBOB, that link didn't work as we aren't facebook friends - which flat lenses did you use? interested to see that pic of the results.
TRBOB #524708 29/07/18 08:59 AM
I used the standard stuff but with stainless guards. Small plastic zip ties secure them th the spring clips which are drilled / fitted to the headlamp rims. No problems whatsoever with retention coffee
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
