11 members (John Winn, MartinB60, Davetherave, Hamwich, JMcL, Graham, G4FUJ, gomog, MartO, Robbie, Alan Patterson, Grumpy2),
204
84
Topics49,871
Posts837,682
Posts: 82 |
After a few hairy moments going over the Black Mountain  in the Wales tour I think I should change my tyres. Can anybody recommend a good tyre. It has Continental on at the moment, don't think I want the same again ! size is 205/55 16 91V
'99 Morgan+8 4.6 '35 Hudson Terraplane Sedan '35 Hudson Teraplane Coupe '10 Alfa Romeo Mito
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have Yokohamas on the Plus8. Fairly "sticky" in the dry but , like any Plus8 the wet is a different matter when "pressing on"!  Glad you enjoyed the Black Mountain road too! If I am travelling close to it them I often detour onto it. How much traffic was on there? Usually busy on a dry Sunday.
Posts: 2,432 Likes: 17
Posts: 2,432 Likes: 17 |
I too run Yokohamas on the plus 8. They are around 6 years old now and I suspect they have gone hard cos things can get a bit hairy. Loads of tread on them and spare unused! This is common to sticky semi track day tyres although they are fine in 'normal' use. You need to get them warm hence less grip in this cold damp weather. I would have thought Contis were one of the best but perhaps you have the same ageing problem? Sorry can't recommend anything, Vredestein seem good on 4/4's and Toyo's on Aeros. Remember Art you were trying to keep up with smaller engined Aeros over the weekend!!! I will follow this thread with interest....................
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 4,896 |
I have Bridgestone Turanza ER300 on my +8 which I find pretty good, but suspect theres better out there. The best wet handling tyres I have experience were Dunlop Sp Sport on a 944 Turbo, but they may have changed since then. Goodyear do EfficientGrip model that is A rated for wet and although I have not tried myself other Goodyear tyres I had on other cars have been good. Be very interested in what tyres other +8 owners are using.
Adrian
Posts: 105 |
I also run Yokahamas on the plus 4, had Continentals on the tin top when I bought it but changed to Yokohamas when they wore out, both winter and summer tyres gave the quietest ride and better fuel comsumption. Plus 4 has plenty of grip when I am allowed to give it a bit of welly (out on my own) so quite happy with them.
Morgan 4/4 2004
Posts: 82 |
with horizontal rain, wind and mist nobody apart from a couple of modern tin tops. I had to back off at the top to let them pass visibility about 10% !!! and no grip.
Posts: 82 |
I also run Yokahamas on the plus 4, had Continentals on the tin top when I bought it but changed to Yokohamas when they wore out, both winter and summer tyres gave the quietest ride and better fuel comsumption. Plus 4 has plenty of grip when I am allowed to give it a bit of welly (out on my own) so quite happy with them. found this online supplyer - http://www.tyres-pneus-online.co.uk/car-tyres-205-55-16-91-V.html prices seem cheap ! Yokohamas seem to be the consensus at the moment
Posts: 614 Likes: 1
Posts: 614 Likes: 1 |
Yokohama AO48 good if being run in dry only, otherwise Toyo Proxes. There are many Yokohama varieties!
Morgan 4/4 Sport Competition
Posts: 82 |
Yokohama AO48 good if being run in dry only, otherwise Toyo Proxes. There are many Yokohama varieties! There are also quite a few Toyo Proxes, could you single any out? Thanks everybody for all your comments
Posts: 614 Likes: 1
