9 members (Morganmike, Graham, G4FUJ, Dougie, Oliemog, flyfisher, Craig Jezz, Pyewacket, Grumpy2, DJC),
209
42
Topics49,911
Posts838,145
Posts: 96 |
Thanks chaps - your advice was taken onboard and a Panhard rod is ordered  As you've all said - no downsides.
1994 Plus 8
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Thanks chaps - your advice was taken onboard and a Panhard rod is ordered  As you've all said - no downsides. Hi there - who did you order one from?
Richard 1976 4/4 4 Seater
Posts: 96 |
No idea - Bill Wykeham is getting it sorted for me.
I would guess it'll come from Mulfab though..?
1994 Plus 8
Posts: 14,009 |
More than likely. They make the factory ones I believe.
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
I have used a much simpler approach to control the sideways effect on the rear cart springs which is as effective as a panhard, yet costs next to nothing.
I simply fitted a piece of oak between the spring clamp & the chassis ( On the offside & nearside) using existing Shock absorber bracing hoop fixings, then greased the wood where the spring clamp rubs up & down as the axle moves up & down,this prevents any side movement Ive had this in place since august 2011 ( approx 10k miles) & there is no wear of the wood, there is no noise , no adverse effects & no cost.
I have posed some pics on flickr you should be able to view them at [img]http://www.flickr.com/photos/55174869@N05/[/img] sorry i don't know how to post pictures
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
That's very neat!
1972 4/4 2 Seater
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
I like your work...
I like your work... +1
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Slight risk of the Panhard Wood Weevil.
+8 4.8
