9 members (Dougie, Oliemog, flyfisher, Morganmike, Graham, G4FUJ, Craig Jezz, Pyewacket, Grumpy2, DJC), 196 guests, and 45 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,145
Page 2 of 5 1 2 3 4 5
marcos Offline OP
Thanks chaps - your advice was taken onboard and a Panhard rod is ordered smile
As you've all said - no downsides.
1994 Plus 8
Hi there - who did you order one from?
marcos Offline OP
No idea - Bill Wykeham is getting it sorted for me.
I would guess it'll come from Mulfab though..?
1994 Plus 8
More than likely. They make the factory ones I believe.
Thanks both...
I have used a much simpler approach to control the sideways effect on the rear cart springs which is as effective as a panhard, yet costs next to nothing.
I simply fitted a piece of oak between the spring clamp & the chassis ( On the offside & nearside) using existing Shock absorber bracing hoop fixings, then greased the wood where the spring clamp rubs up & down as the axle moves up & down,this prevents any side movement Ive had this in place since august 2011 ( approx 10k miles) & there is no wear of the wood, there is no noise , no adverse effects & no cost.
I have posed some pics on flickr you should be able to view them at [img]http://www.flickr.com/photos/55174869@N05/[/img] sorry i don't know how to post pictures
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
That's very neat!
1972 4/4 2 Seater
I like your work... thumbs
+1
Slight risk of the Panhard Wood Weevil.
smile
+8 4.8
