Topics48,347
Posts813,063
Posts: 7 |
has anyone had corrosion where the little light sits on top of aluminium wing? If so how did you treat it?
Posts: 26,748 Likes: 419
Posts: 26,748 Likes: 419 |
Sorry no. I would guess it is galvanic and driven by aluminum touvhing steel. In that case you need to insulate the 2 metals
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Doesn't the light come with a rubber base and the nut with a similar "washer"?
Richard 1976 4/4 4 Seater
Mine does & touch wood no corrosion. My wings are ali but pre superform
Posts: 676 |
One of the guys at Lifes told me that is quite a common problem with older cars with aluminium wings due to galvanic corrosion, as John said. Its a regular repair on some cars apparently while they are being prepared for sale. Even with insulation the threaded part of the light fitting can come into contact with the wing.
1989 911 Porsche Carrera Land Rover Series Defender 90 SW
Posts: 5,366 Likes: 15
Posts: 5,366 Likes: 15 |
I also had corrosion on the cowl on my '09 +4 where the Mog badge was fitted. Shame as Fords used to fit their trim using little plastic cups 50 odd years ago to prevent this!
Lowebird
