9 members (CooperMan, Neville1, Cerberas, Pittsartist, JMcL, RichardV6, Craig Jezz, MartinB60, GrumpyPa),
321
128
Topics49,869
Posts837,659
Posts: 536 |
No I haven't and nor I am sure it's easy to get to. However since she start's ok when the + of the battery is connected to the + point front of the block (you might need to see an Aero 8 S1 to understand what I mean) then that leaves me pretty convinced that the problem is on the positive supply side to the starter.
Cheers
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
That would be the logical assumption Philip. Good luck with resolving the problem.
Posts: 1,597 |
Cheers Philippo, How have you an update on the starter problem. I am interested as I am running a new battery now for 6 months and so far no clicking. You suggested that the problem may be on the positive supply side, always useful to know what you discovered. Dave
Posts: 169 |
Phillipo
Also seeking an update if possible as I am now experiencing the click 1 in every 3 attempts to start her, hot or cold.
Thanks Andrew
Posts: 40 |
Andrew, Had the same problem over many years with my S1, problem now fixed by Brian Miller, new uprated starter/solenoid. Excellent job. David.
Posts: 169 |
Thanks David. Booked in with Brian tomorrow to get it fixed, a service and MOT
Posts: 536 |
Hello and apologies for not posting on this subject for a while; in the process of a house move and reconstruction project!
Since early June the car has been starting fine, so haven't been able to confirm my theory about issue on positive supply side. It's also been a lot hotter here in Toulouse....coincidence or what that starter working fine?
Cheers
Philip
Posts: 318 |
Hi
My S1 failed - this is a common issue and I was told that the replacement is a modified Bosch variant that wont suffer the same issues.Strangely mine also worked OK when I was in the hot south of france but in the UK would not start one in ten .
good luck
Gajet
2013 Plus 8 Aero S5 Build week 11
