3 members (Montegue, jbk, SteveD),
204
80
Topics49,847
Posts837,386
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Mine does it on any petrol including V-max and the BP equivalent. My guess is that it is ringing of the cooling fins but really don't know for sure.
Posts: 40 |
I do tend to treat it to the best from Esso or Shell so don't think it's the fuel
Posts: 417 |
Same issue for me. Have been wondering what the sound is. Will be an interesting thread
blake sfmorgan.tumblr.com
Posts: 782 |
Mine does it too, but only on heavy throttles, so I tend to avoid higher revs. If I use less throttle it is much reduced. I thought it was to do with the throttle cable but it could be pinking I suppose. It's certainly not imaginary, and I only use Shell or similar extra special juice.
Will now feel confident to raise it at dealer... Sort of pleased they all do it, but sort of frustrated too because I know what that means in terms of what the dealer can do...
Posts: 6,538 |
Could be Pinking - fuel is so very variable in quality - try some "Super" and see if the higher octane helps? I have not had this problem.
Neil
Posts: 417 |
don't think it's a fuel issue to be honest. i've had it every tank of gas i've used and i only fill up with premium and i use a different gas station almost every fillip for the last 3,000 miles
Posts: 40 |
This noise seems to be getting more pronounced, I'm coming to the conclusion its probably pinking, as mentioned by others the noise is louder on a bike engine, with a car it's more of a tinkling sound because of the sound proofing and water jacket - this is like stones being thrown against the mudguards.
I'm using good fuel so assume ignition timing needs looking at
Posts: 214 |
Hi, mine went in for its first service at 1,100 miles and magically came back with pinking on full engine load. I am going to ask if they re-mapped the ignition during the service. No pinking present before the first service.
Plenty of squeaking from the compensator though!
Posts: 40 |
That will be interesting if you can find out
Posts: 782 |
Yes, mine sounds like the throttle cable is getting bombarded by stones if a heavy throttle is used. If it's pinking I've neer heard anything quite like it before...
